Question about Black & Decker 3/8" Cordless Drill Kit
Duff battery Can battery pack be repaired. Checked cost of new assembly and itis horrific. Pack is secured by tamperproof screws so will need to buy a suitable screwdriver first if worthwhile.
  • 508 Answers
Drill heads of screws off
Posted on Jul 03, 2009
Can I dissasemble a BP-210N battery pack and refill it?
You could do this absolutely, however with the cost of the batteries needed and the knowledge needed to safely solder to batteries terminals it is more cost effective and safer to purchase from Ebay.
$16.99 coming out of Gardena, Ca with free shipping BATTERY FOR ICOM BP 210 BP 222 BP 210N BP 209N BP 222N
Oct 02, 2015 | Radio Communications
How to replace a battery in a waring pro wine opener
Replacing requires some soldering skills.
1. Remove two screws in bottom end and pull off the bottom sheath.
2. Remove six rubber plugs that camouflage six screws.
3. Remove the six screws. The opener will come apart in halves and the motor assembly may drop free but will still be connected so be a little careful. Take note of the orientation of the larger spring near the bottom and the positions of fittings that mate with the shell.
4. Unsolder two leads connected to the old battery pack and remove it.
5. Now you have options for replacing the battery pack. The pack consists of four Nickel Metal Hydride batteries connected in series.
a. Buy replacements (I didn't do this so I don't know if a pack is available that is already assembled). You might have to buy four same-size batteries and assemble the pack yourself. You can determine size by cutting the shrink wrap away from the battery pack to expose the actual batteries.
b. Buy standard AA (or AAA) cells, rechargeable (Nickel Metal Hydride) cells that are readily available everywhere.
6. (Unnecessary if you found a pre-assembled pack). Assemble a battery pack by soldering battery terminal to battery terminal such that all four batteries are in series. You can arrange adjacent batteries with a plus terminal and a minus terminal next to each other. You can make the four batteries into a pack by winding them with electrical tape.
7. (Unnecessary if you chose step 5A). Using a sharp knife or a Dremel tool, whittle away most of three ribs that are formed into the plastic shell. There are two ribs to do in one of the shell halves and one(+) rib in the other shell half. The (+) rib is near the connector block mounted under the operating switch and you can decide how much of it to whittle away also. The objective is to get the new battery pack to fit in the shell halves when they are re-assembled.
8. Solder the plus(red) wire and the minus(black) wire to the new battery pack -- those are the two wires removed in step 4.
9. Add padding if you desire to keep the battery pack from rattling around inside the shells.
10. Reassemble the shells and the bottom sheath.
11. Enjoy your wine.
Nov 20, 2013 | Waring Pro WO50 Cordless Wine Opener
Looking for a part for the above jiffy Lite model. On the back of there's a part that is screwed on with 2 bolts to the frame (the horizontal bar just above the battery housing area). This part is silver...
repetto Try taking a plastic tie wrap that is long enough to wrap around the post on the battery case and the clasp this shoukld keep it in contact until you can find a part. You shoukdn't need to replace the battery pack just the clamp. If shoprider wants you to by a battery pack just to replace the clamp why? you might try looking for a guardian red small wheelchair it uses the same clamp to hold the battery pack and they no longer make that chair someone might have a junked one that you can get the clamp from just a thought Hope this helps
Apr 05, 2011 | Shoprider New Xtralite Jiffy Power...
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Aug 28, 2010 | Garden
I have the rechargable battery pack and one remote has stopped working. If you press the power on button the blue lights go on then nothing happens do i need a new remote? I have swapped the other battery...
Hi usually the blutooth dongle has gone foul, easy to fix buy a blutooth dongle off ebay should cost about 10 bucks and free postage from the boyz from china. Open the WII console (you will have to buy a triwing screwdriver unless you have one with phillips screws) remove the rom and under the chrome shield under the rom undo enuf screws just to slip it under and press it down. Look at the one you took out it should have a type of packing on it to prevent it falling out when you give it a good knock so see if you can transfer the sponge type from the old to the new Good Luck
Feb 27, 2010 | Nintendo Wii Console
Tired old Dewalt dw056 impact driver
It needs a new battery pack. Rechargeable batteries eventually wear out and no longer hold a charge. The tool runs only briefly and the battery is exhausted again. The big home centers and online sources sell replacements. There are also companies that say they can rebuild your battery pack at much lower cost than replacement. I have no experience with them.
Apr 23, 2009 | Dewalt DW056 18 Volt Cordless Impact...
How to take apart panasonic battery pack ey9230
The screws are a T10 tamperproof torx. After removing the 4 of them you need a small pick to push into the holes on both sides of the battery while applying some upward pressure on the top case. There are small clips in the top housing that you are trying to release. Let me know if I can help further
Mar 14, 2009 | Panasonic Drills
Sir My camera's( olympus stylus-1000)batery is in trouble. could you please give some authorization service centers in Cochin , Kerala, india. Your"s faithfully subhash
"sir
My camera's( olympus stylus-1000)batery is in trouble."
Hah! I love that! Not making fun or nothing, but many people aren't as polite to put "Sir or Madam" before writing things down. Very polite. :D
As for your battery; it'd be easier just to buy a new battery pack from off the internet, as repairing a battery pack would be impossible, or cost as much as buying a new pack itself.
Nov 30, 2008 | Olympus LI-12B (200838)
Black & Decker 3/8" Cordless Drill Kit Logo
76 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
