How do I get to the inside of a sony vaio PCG 6F1L. The ac jack is loose and I need to reseat it.
Need to download all drivers for a Sony VAIO PCG-6F1L notebook with Windows XP Pro SP3 installed.
Cant find that model anywhere, the support page is here http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_gb&m=0&s=Please+select
If this is not your country just take another look at your model number and go to the sony vaio support site for your country.
Aug 20, 2010 | Computers & Internet
How do I remove the hard drive on a Sony Vaio model PCG-6F1L laptop?
u need to remove it from the bottom of the notebook...u may need a diagram of the notebook for it...remove some screws and remove the cover etc...
Dec 25, 2009 | Computers & Internet
How do i replace the hard drive on a sony vaio pcg-6f1l
on the bottom of the laptop where the battery is there are different panels under one of those panels is the hard drive the panel will be about 10cm to 15 cm long.
Dec 24, 2009 | Sony Computers & Internet
Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
you can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
please take a rating let me know how much helped you thanks!
May 21, 2009 | Sony VAIO V505DC PC Notebook
I need drivers for the sonvy vaio PCG-6F1L!
That is because the actual Sony model is VGN-S360.or VGN-S360P You should be able to verify it. The model nember is not on the bottom it is on the RH LCD hinge. I do not think you can download the drivers anywhere but you can try:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNS360
or just buy aa set of recovery DVDs from Sony
If you have the VGN-S360:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537841&searchOperation=modelSearch&searchText=VGNS360
If you have the VVGN-S360P then
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=537842&searchOperation=modelSearch&searchText=VGNS360P
Mar 22, 2009 | Sony Computers & Internet
I would like to replace the hard drive in my Vaio PCG-6F1L notebook and can not figure out how to open the case. there is one release I am missing. Bruce
Usually there is a side or a bottom part of the case where you can pop the hard drive out. My best advice is to refer to a manual or sony directly.
Jan 26, 2009 | Sony VAIO GRX550 Notebook
Help!!!!!!!!!!!!!!
It's probably the power socket on the laptop not the power jack on the AC adapter. You need to open the laptop by removing the casing screws. Then remove the motherboard from the base so a new socket can be soldered on.
Apr 02, 2008 | Sony VAIO PCG-V505EC Notebook
Sony vaio pcg 6F1L
Do you mean clean inside the LCD itself?? did it get water in it??
Not a fun thing to take apart an LCD and hard to reassemble as well. If you break the circuit boards while taking it apart you have to buy a new LCD.
Here is a good example of what replacing a backlight involves including disassembly pictures:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
