Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Replaced control board Kitchenaid KBFA25erss refrigerator
Replaced the control board located in the bottom lest rear of the refrigerator. I need the code for the control board to reprogram the unit.
  • 56 Answers
Should be on the serial plate
Posted on Jul 03, 2009
Where is main control board located on kitchenaid kbfs22ewms9 refrigerator
I haven't seen the exact model of this refrigerator byself but mostly main pc boards in old model refrigerators back bottom near left side of the compressor... Otherwise you can find on top surface or in the middle of back of the refrigetaror.. That pc board will be covered in plastic box
Oct 15, 2016 | KitchenAid Refrigerators
Tip
KitchenAid, Whirlpool side by side refrigerator remove the main control board...
Electrical Shock Hazard
Connect green ground wire to ground
screw.
Failure to do so can result in death or
electrical shock.
REASSEMBLY NOTE: Be sure to reconnect
the green ground wires; one to the compressor
terminal, and the other to the chassis (see the
previous steps).
7. To remove the main control board assembly:
a) Remove the unit compartment cover
b) Remove the two hex-head screws from
the rear of the main control board assembly
enclosure, and position it so
you can access the board.
c) Remove the wire connectors from the
main control board assembly.
KitchenAid, Whirlpool side by side refrigerator Component Location and removing cover
http://www.fixya.com/support/r5759997-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
on Aug 27, 2010 | Refrigerators
I have a GS5SHAXNL00 Whirlpool Conquest refrigerator. This morning I opened the door to the unit and the light is flickering very faintly and there was a rattle sound coming from the bottom. When I press...
You have a faulty control board that will need t be replaced. Here is the board to order. The board is located on rear bottom of the unit.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Whirlpool Refrigerators
What water filter do I need to buy for my kitchenaid refrigerator model #KBFA25ERSS00
The correct water filter for you is 4396396. You can purchase this at:http://www.kitchenaid.com/flash.cmd?/#/accessory/4396395/
Kitchenaid offers free shipping and 10% off this month with promo code "FREESHIP" and free shipping with discounts for 2 and 3 packs of this filter.
Feb 02, 2011 | KitchenAid Architect KBFA25ERSS Stainless...
KitchenAid evaporator fan replacement
the correct procedure is to hold the motor n pull the fan blade out holding from the central n removing the clips if any.it should be replaced if its worn out
Jan 18, 2010 | KitchenAid Architect KBFA25ERSS Stainless...
Kitchenaid Bottom mount refridgerator is has stopped cooling but freezer is maintaining correct temperature
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/36832aba1a29de4d852570ad004ec13e/$FILE/FDBMREFRIG.pdf
We replaced the evaporator motor. Use an Ohmmeter to see if electricity is going there, first, see if fan is running, then, if not, replace evaporator motor-part # 12002744.
Fridge is now running! I'll post again, if there is any more to the story. We are now waiting to see if it gets to temp, but it is running. I'd love to find info on a reset code.
Sep 23, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Dec 24, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
369 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
