Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to fix a crack in an interior refrigerator liner?
  • 56 Answers
Whirlpool has a repair patch kit drill a small hole at each end of the crack to keep it hrom speading
Posted on Jul 03, 2009
How do I get water out from INSIDE the bottom liner beneath the fruit & veggie bins? There is a small crack in the liner and water is leaking out from it.
My name is Peter, I am a retired Sears Home Services Tech. This could be a serious problem. When your liner cracks, moisture gets into your liner - it freezes and expands cracking the liner.
You need to get a hair dryer . Heat the area. Try to get as much liquid our of the cracked area. Be patient, You need to get a good Silicone water proof sealant. If you do not dry out the insulation material the problem will continue. Please let me know how you
make out. 443-306-1362.
Oct 11, 2014 | Refrigerators
The interior is cracked in my freezer. What do I do? Is it safe to still use?
dont do anything, you would need to replace the liner and it is not even done by pros. It wont hurt a thing to use it with a cracker liner
Oct 12, 2012 | Refrigerators
I have a whirlpool side to side fridge which is 10 months old. The liner has a crack in it. Whirlpool is telling me that they will put a piece of tape on it to fix it. THis is not acceptable to me. Any...
Hello Tracey,
On that the best thing i can tell ya is "the squeeky wheel gets the oil" their is not part that can be replaced to fix the liner.The entire refrigerator must be replaced to remedy that crack.
By keeping on them while in the warranty period Whirlpool may relent and give ya new refrigerator
GENE
Oct 12, 2011 | Refrigerators
How do I fix the crack in liner of my fridge. its getting more all the time. is there something wem can but to fix it?
If you are a little bit handy, fo to your auto parts store and get a small fiberglass body repair kit. Read the directions. Make sure you have the edges of the crack smooth and level with each other. Cut a piece of the cloth that comes in the kit that will cover the crack. Carefully mix the resin and hardener that comes in the kit. Then working quickly spread it smoothly over the cloth. Let it set up and sand smooth with 120 grit sand paper. If you want to try to match the interior color of your refrigerator, you could spray paint just the area that you patched.
Sep 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Interior thermal of refridgerator is cracked
If you are talking about the inner liner then you cannot change that. Seal it with silicone if it bothers you.
Sep 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
Broken crisper shelf supports
What up G? (jk)
Look, I'm not really sure about this, but it sounds like you may have a warranty issue here. The reason I believe this is because those supports are actually part of the liner (which CAN NOT be removed, btw) and the liner should have a really kickin' warranty behind it. Check your owner/user manual for warranty info and see if I'm correct.
If I'm wrong then it's gonna be a pain to ever keep those supports in place. Whirlpool had a liner problem not long ago and "issued" an authorized repair for it which utilized an epoxy resin and other materials. But if memory serves, that was just for cracks in the liner, not functional parts of the liner breaking away.
Hope this helps,
SG
Mar 23, 2009 | Refrigerators
Whirlpool Refrigerator Internal Liner Cracks
If it is a Kitchenaid brand, the liner is covered under full factory warranty for up to 5 years. (See your warranty guide page). I am the Svc Mgr of an Authorized service center and relayed to one of my customers this morning, that if they took photos after the repair was made and call customer service, they will tell you where to send them. If...and they will agree the repair is un-sightly, you get an exchange. I am not sure it will work with the Whirlpool brand even though they are in the same family ** all made by same company, Kitchenaid cost more and comes with a longer warranty.... hope this helps. Florida
Mar 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My maytag side by side model #RSW22EODAM refrigerator door has a
If all you need are shims, use washers (either plastic or metal) with an interior hole large enough to go over hinge pin to raise door. However, in reading your complaint, I feel as though shims (or washers) may not solve your problem. You may have an issue with the door seal and or door liner. Sometimes a new seal will correct the problem but check for any cracks in the door liner. If cracks are evident, you will need to replace both. Putting a door seal on a cracked liner will NOT help. If you need to replace both, it can get a little costly. Good luck.
Dec 06, 2008 | Refrigerators
There are hair line cracks in the side wall panel of the inside lining of the refrigerator that run parallel to one of the shelves. Any thoughts? Kitchen Aid S/S REFRIG. KSRG25FKSS
im thinking you got a cracked refrigerator liner!! heres the problem with that, its strictly a cosmetic issue, in years past kit aid would consider that a non-field repairable issue and change to refrig out for you.now they've come out with a repair, consisting of an epoxy kit that we go out and epoxy the crack(s) for you, although still noticeable far less than a cracked liner. if necessary and enough cracks in wall they have an epoxy liner kit that will cover entire side wall of the refrig, all depends on the affected area. ive done quite a few epoxy repairs, never a complete panel, but the few epoxy repairs ive done the customer seemed satisfied with the result..again strictly cosemtic issue so ifyou leave it alone oyou will be endangering absolutly nothing exept an unsightly crack.
Mar 17, 2008 | Refrigerators
Frig liner is cracking
I have the same problem on my 3 year old Kenmore Refrigerator. I cleaned out the refrigerator and noticed the cracks. I don't know how long they've been there. I called the service guy out and he said it's a known problem. He said the plastic wasn't poured right into the mold. He told the only solution is a silicon type caulking or a patch. The patch involved cutting pieces of liner from a sheet and basically glueing them over the cracks. BOTH SOLUTIONS are unacceptable. I am beginning the process of complaining (lot of good it will do). If this is a known defect, SEARS should stand by their product and make it good.
Aug 28, 2007 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
900 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
