Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Brush won't turn, and fluid does not come out when using the upholstery attachment.
  • 508 Answers
Broken belt
Posted on Jul 03, 2009
Brush stays on when upright
You are correct, the brush will continue to rotate when using the upholstery hose as stated in the user guide.
The burning smell may be contributed to a couple of different reasons. Make sure the front of the vacuum is not being tipped or tilted forward when using the upholstery hose.
If you continue to have difficulty, you may want to have a one of BISSELL's Authorized Service Centers inspect your vacuum.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 12, 2013 | Bissell 3522 PowerForce Bagged Upright...
I do not understand how to use the upholstery
Please reference this user manual, starting with Page #11. I believe it will guide you thru it.
http://www.hoover.com/pdfs/manuals/F5891900.pdf
Oct 11, 2009 | Hoover F5892-900 SteamVac Upright Vacuum
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Does my kirby come apart to where i can shampoo furniture . can i use kirby on berber carpet. i have the G series
YES there is Kirby upholstery shampoo attachment that comes in a standard set of attachments - HERE is the instructions. Try it on inconspicuous area first just to make sure that this is going to work on your upholstery. But I would just buy a can of upholstery foam. If you can not find it in a store - try automotive store - they definitely have it. Spray can is just much more simple. Still try it somewhere where you would not be afraid to damage the color first.
Using shampoo attachment on berber carpets is not as effective as on the regular carpet. Brush cant get to brush the fiber from all sides. You may have to shampoo berber rugs from several directions to get the better result.
Mar 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentra
Remove the bag assembly from the machine.Install the hose to the machine.The upholstery shampooer is simply a trigger assembly with a jar attached.Simply connect the back of the trigger ***'y to the end of the hose.On the attachment case is a cloth covered cap that goes on the other end of the trigger assembly.This is what creates the foam.Fill the jar with shampoo solution.Use the trigger to deposit the foam onto surface.Work the foam into fabric using soft cloth or brush.When it's dry,vacuum the foam and dirt out using the hose attachment on the suction side(front) of the machine
Nov 07, 2008 | Vacuums
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
How do you use and what attachments for upholstery cleaning with the Heritage II
Generic problem for all Vacuums
How do you use and
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Kirby has a spin brush that is round on the newer Kirby’s and it works on the suction from the vacuum and it fits on the end of the vacuum hose but it does not fit into corners very well or your can take some Kirby shampoo in the spray water bottle and use a kitchen scrub brush for the corners. Other wise you can use the actually Kirby Shampooer of which is very hard and unfriendly; the spin brush would be my selection. You can check with your local vacuum cleaner dealer in your area and also in the yellow pages. Also you can call the Kirby factory to see if they can direct you. The Kirby factory is listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 18, 2008 | Vacuums
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
260 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
