Question about Belling Cooktops
I'm looking for the wiring instructions for a Belling format cooker. I have purchased a new Oven thermostat and the old one is not wired the same way as the new one. The old part is 47THC33/215 an dthe new one is ET54001/215. Connectors 1 to 6 correspond but the bottom connections don't (marked A, B, C) - any ideas
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Belling Cooker Hob Cracked
Nope
Posted on Jul 25, 2007
reg501
  • 413 Answers
SOURCE: stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
rickead1
  • 1998 Answers
SOURCE: removed faulty oven switch and drew wiring
what is the make and model number of your cooktop? Thanks
Rick
Posted on Dec 19, 2010
oldTech2332
  • 2341 Answers
SOURCE: helping a friend install a
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Posted on Sep 07, 2011
Need a wiring diagram
Most appliances have a wiring diagram inside them. (I know washers, dryers, and fridges do). Have you checked to see if there is one? Usually they are printed on green paper and folded up. Obviously for an oven, they'd have to be away from the heat source. Maybe near the control panel on the back, or if there is a storage drawer on the bottom of the stove, it might be in there, or taped to the back of the drawer.
Apr 08, 2013 | Maytag MER7662WQ - 30"Self-Cleaning...
I need to know the wiring diagram for the controls on zanussi zce 7700x. i just got a new thermostat which i need to put in but need to put the 2nd oven controls back right . thanks
Sorry to read about your problem, I hope this helps you out.
you dont need a wiring diagram, the part should be a direct replacement.. wire for wire..
if not you got the wrong part
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
I have an Amana smoothtop AK2H35 the large dual burner seems to overheat. It gets so hot, that everything burns, when I turn the temp down, the burner does not turn off, though eventually, it does turn...
Hello there
I will answer this in 2 sections for testing the burners and the thermostate
Surface Burner Testing:
In order to test the surface burner on your electric range, the following steps should be taken:
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Remove the surface burner from the stovetop. On most electric ranges this can be done by pulling the burner up and out of its plug-in receptacle. Other models have the burner directly wired to the cooktop. To remove this type of burner, undo the screw that secures the burner to the cooktop, remove the clips that secure the insulators to the burner terminals, and carefully unscrew the wires from the terminals. Take care not to bend these terminals.
  3. Visually inspect the burner - often there will be small holes or bubbles on the surface of a defective element.
  4. Now that you have removed the burner, you can test it using your VOM. Using the ohmmeter function, set the range scale to R x 1 and touch the test leads to the two burner terminals. The VOM should show continuity. Typical burner readings should be somewhere between 19 and 115 ohms, depending on the range manufacturer. If there is no continuity, the burner is defective. To test for a grounded (or shorted) burner, place one test lead on the outside surface of the burner and the other test lead on each burner terminal in turn. If there is continuity at either terminal, the burner is defective.
  5. If the burner is defective, replace with a new one by reversing the removal procedure (step 2 above). If replacing a wired-in burner, make sure that you install the wires on the correct terminals, according to the wiring diagram
Oven Thermostat Testing:
An oven thermostat is a switch that opens and closes in response to the temperature it senses. It is typically found in the control panel, where a liquid-filled temperature-sensing bulb senses and maintains the internal oven temperature by cycling heat on and off.
  2. Access the oven thermostat, which is located in different places depending on the make and model:
    1. On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends.
    2. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components.
    3. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel.
    4. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you.
    5. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
  3. When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced.
    Adjusting the thermostat:
  4. Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
  5. If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Dec 01, 2010 | Amana Cooktops
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
After running the self-clean feature on my 21 year old Beaumark stove all of the indicator lights (oven, burners)are not working. The clock (not digital) is not working either. Oven and burners are still...
you may have a temp thermo on the back or the top of oven . hi tempt would have shut off electrical . should have shut the oven off also / wiring in top may be faulty. now if the top burners are working but the clock & oven are not then you have a saftey thermo out . you may need to repl with new one . some ary resetable. take the old one to a appliance parts co . so they can read the tempt,s on it ,. should be able to match .. mm
Nov 20, 2009 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
' Fagor 2h-134 I ' cooker manual needed
Hello
Are you looking for the pressure cooker manual?
Jul 12, 2008 | Fagor Cooktops
Two elements not working
First of all, are you sure it is the elements and not the controler? To test the elements, lift theplate out of the worktop, change the 2 wires from a good element to that element. put the plate back in it is home and use the good elements touchtronic button to turn on the element. I am willing to wager that it is the control unit and not the elements.
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Stove top dual infinite switch
Regards,
reg501
Jun 24, 2008 | Cooktops
Cooktops Logo
98 people viewed this question
Top Belling Cooktops Experts
Paul Carew
Are you a Belling Cooktop Expert? Answer questions, earn points and help others
