Question about Whirlpool LER4634J Electric Dryer
My electric dryer runs for a few minutes then shuts off. You can restart it almose immediately.
    President:
  • 1,723 Answers
Probably the door switch. Is it closing tightly? Open the door and look at the switch, is it loose or any signs of problems. Try putting some tape on the edge of the door where it makes contact with the switch and see if it makes better contact.
Posted on Jul 04, 2009
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Dryer starts and immediately shuts off
Hello sdbruflodt- First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Dec 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer starts to dry but then shuts down after 5 minutes...why?
That is usually a sign of a bad motor. Can you immediately restart or do you have to wait a while?
Nov 02, 2010 | Whirlpool LER4634J Electric Dryer
Runs, but shuts off after a few minutes, wait a little while and it will restart
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Roper REX4634KQ Electric Dryer
Dryer shuts off on own. Can't restart right away.
if it is electronic activated(push bottom with digital lcd) have it reprogram in repair center,
if it is manually dialed then have it change
Nov 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs for a few minutes, then shuts itself off
Sounds like your husband has his work cut out for him.
Here's the drill.
Dryers today have series of thermostats and fuses to prevent fires.
I have seen some with as many as 7 total.
Each needs to be tested with a multi-meter or an ohm meter to see if it has popped.
Any one of them could have.
Wait to test them until after the machine has "died".
It might help to sit watching the rear of the machine and watch for the one that fails, they will often "pop" loud enough to hear them.
God bless your efforts.
Oct 20, 2017 | Maytag Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Mar 12, 2009 | Dryers
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
133 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
