Con-air mini split-at any temp setpoint outside unit cycles but inside blower runs all the time.
  • 3 more comments
  • dorishenning Jul 03, 2009
    seth, remote is in auto mode. I've lowered the temp, to cool the room and then raised it to above "satisfy" point , outside unit cycles off and blower doesnt
    thought that was probably the problem, but unit is only 3 months old and i didnt want it to be. bought online at wholesaleac.com. do you have any manufacturers info so i can get warranty parts.
    AIR-CON ACN13-24HPCEV
    North Georgia/ Western North Carolina
  • dorishenning Jul 06, 2009
    seth,i'm in warne nc - i didnt get the phone #
  • 334 Answers
Have you made sure that the fan is in Auto? You can change it from On to Auto on the remote control. If this is not the issue, let me know.
seth
Posted on Jul 03, 2009
  • 3 more comments
  • seth veloso Jul 03, 2009
    Ok, chances are the blower relay is welded or stuck closed. I am not exactly sure what you have in your unit but chance are the relay is on a circuit board. A small black box on the board. If you can find it (probably in the control panel behind any buttons on the unit) you can try to tap on the relay to see if it releases. If it does not, it should be replaced. If it does, it will probably happen again and should be replaced anyway
    seth
    sure, tell me the model number
    sorry, one more question, where do you live
    Hey, I live in morrieville, nc. Here is heir US phone number in florida, you may have to wait untill monday to contact their parts counter but they should be able to help you out. It is kind of off the wall name brand, I have no idea who carries their products locally. Let me know if you need anything else.
    seth
  • seth veloso Jul 06, 2009
    sorry about that, here you go
    Tel: (954) 885-7420
    seth
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Outside unit freezing
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
Feb 06, 2018 | Ingram GMS90904CXA Heater
I don`t know if the (GOLDSTAR BWHD5000) back part of the air continioner must be outside of the room, or can I have it into my room with windows and doors closed?
hello there, if your air conditioner is window type the back should be outside. if your air con is split type the blower or air vent should be inside. if your air con is tower type it should be inside. this could be help. thanks
Apr 25, 2011 | Heating & Cooling
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
For how long time to keep AC on?
The Department of Energy recommends occupied setpoints of 70degF Heat and 78degF Cool. During unoccupied times, it is recommended to setback Heat to 62degF and setback Cool to 85degF.
If your system is experiencing problems "catching up" from a setback temp setpoint, you will need to adjust these temperature setpoints to allow for your system's capabilities as well as your individual comfort needs.
In short, you will have to find a balance point between your body's comfort and your wallet's comfort.
You also want to make sure you keep your air filter clean. If you have access to your condenser coil (the part outside), wash it down from time to time using a water hose.
I don't know what your location is, but I'm including a link from the state of Michigan which offers some helpful information and advice on how to keep your system running efficiently & effectively.
I hope you found this information helpful. :-)
Mar 08, 2010 | LG Art Cool LA181CNW Split System Air...
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
