Question about Averatec 6200 Notebook
Battery replacement hi all, i have been using avertec 6200 series for couple of years now i am facing battery problem. since i am a resident of dubai (U A E) it is finding it bit difficult to replace it. please advice me where can i find it or a nearst service center. thanking you irshad dubai
Hi i have laptop ACER, ASPIRE 3000 SERIES, Model No: ZL5, Manufactured Date: 0504, ASPIRE 3003WLCi, S/L : LX550523751607C6AEM00. 1. My laptop's battery is not working, could i replace the battery
IF you are sure that your Laptop battery is DEAD then you can surely replace it with working one.
YOu can contact in the below address
Madurai
Softech india Computer Systems
97 North Veli Street,,
Madurai
PIN: 625001
Phone: 0452-4376980
Email-Id: sampl@satyam.net.in
Fax: 0452-4376986
Premier Systems & Peripherals
# 80-A, Yanaikkal, Madurai-625 001,,
Madurai
PIN: 625 001
Phone: 0452-4371666/ 4381010/4381221
Email-Id: senthil@premiermadurai.com
Fax: 0452-2629943
Jul 27, 2012 | Acer Computers & Internet
HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
I recieved a Powerware 9120 1000 with no batteries. It appears all three batteries attach in series. Is this the case? Thanks! Russ
Hi, here is the Eaton page (Eaton acquired Powerware about 5 years ago) with the user manual for the 9120. It doesn't make sense for a 1000 9120 to not have batteries: http://powerquality.eaton.com/EMEA/Products-services/Legacy/Legacy-Products.asp. Also, here is the form to ask for help on this product: http://tools.mgeops.com/form/support/index_hard.php. I'm assuming that you're probably not in the United States so this is the UK-based form.
Oct 24, 2010 | Powerware Invensys 9120 Model 1000i...
I bought one ipod from Dubai 2 years back. some time i was using for a while, for last six months i doesn't work, Is thier any problem with battery, whether battery can be replaced?
Hello :
Since it's two years old , I think that's enough with the old battery . I think the battery is already dead [ can't be recharged anymore ] . Of course you need to replace it . Of course the battery can be replaced .
PLEASE DON'T FORGET TO RATE !
good luck .
Apr 10, 2010 | iRiver E10 Digital Media Player
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
Facing problem with battery of Dell Inspiron 6400
1. Shut down the system, remove the battery and the Ac adapter from the computer.
2. Press the power on button for 10 seconds
3. Reinsert the battery
4. Power on the computer and as soon as you see the dell logo press the f2 key a couple of time
5. Using the up down arrow keys , go to the option that says battery info. If there is an error message listed kindly post it back
6. Otherwise shut down the computer reconnect the ac.adapter and check if the problem is solved
Also the battery has a diagnostic lights on it , remove the battery from the computer and press the button on the battery a set of lights would glow. If they are steady and come in a series the battery is good , If some lights are missing the battery is bad and may need replacement
Thanks
Proton
May 15, 2009 | Dell Inspiron 6400 Notebook
Lexmark 6200 Series Center won't open
Hi John, doing a reinstall is not advised unless you completely remove the software first. (Power off the printer).
Try removing all software for the 6200. Once all of the software has been removed restart the system. Check if the 6200 is still listed in, Printers and Faxes. (If it is listed delete it). Than download & install RegCure, which is a free program that will clean windows registry from all none needed keys. Download RegCure from this link:
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Restart your system when RegCure has finished.
Now you can safely reinstall your printer software.
Good luck John!
Mike
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Averatec 6200- battery
Are you using a travel adapter (converter)?
Nov 27, 2007 | Averatec 6200H Notebook
Averatec 6200 Notebook Logo
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
