Question about LG Electronic Window Air Conditioner
LG 1 Ton Window A/C
I want the outer cover dimensions of a 1 ton a/c so that i can make an opening in the wall
  • 80 Answers
EVERY UNIT HAS DIFFRENT MEASUREMENTS FIRST CHOOSE THE UNIT YOU WOULD LIKE TO INSTALL THEN CALL THE COMPANY OR SUPPLIER FOR THE SIZE.
Posted on Jan 14, 2008
SOURCE:
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
My LG Split 1 ton Continue poor working with under voltage 180V (Due to Long distance Transformer), Once its capacitor have to change this summer. Now i arrange Stabilizer which give 230V. Before...
Unfortunately, there is not a great deal of information about LG splits available, but is you are talking $12,000 to to repair, then it is much cheaper to replace since a two ton complete is less that half that amount.
Jun 30, 2011 | Heating & Cooling
What is the btu of this model.m7q08f2a.
Hi, to find out the tonnage of your unit in b. t. u.'s, look at the 08 in your model number. There are 12,000 btu's per ton of cooling. You have a window /wall unit, and according to the model # 08 is not a 1/2 ton or a 1 ton, but a 3/4 ton unit or 8,000 btu's if indeed this is the correct model number. Most units we come across are in btus as 06 which is 1/2 ton, 12,000 is 1 ton, 018 is 1 1/2 ton and on up with a properly matched indoor coil. Your unit is a package window unit, so both coils are equal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Nov 18, 2010 | Maytag M7Q08F2ACOM Air Conditioner
1 ton hitachi window ac dimensions
quadricool sm)1.1 ton dimension is 660x430x805cm,
quadricool tm) 1.1 ton dimension is ,, ,,,,,,,,,,,,,,,,,,,,
Nov 09, 2010 | Hitachi Heating & Cooling
What is the capacity on my Rheem Classic High Efficiency Outdoor a/c unit. I have a home that is 3200sqf. It seems to be on some type of a damper system... Is this unit big enough for my home?
depending who you talk to a ton will cover about 500 sq ft (as some say 400 sq ft others say 600 sq ft). I believe your unit is a 3 1/2 ton unit. Below is a chart
0sf-750 sf= 1.5 ton
751-1000sf= 2.0 ton
100sf1-1250sf=2.5 ton
1251sf-1500sf=3.0 ton
1501sf-1750sf=3.5 ton
1751sf-2000sf=4.0 ton
2001sf-2500sf=5.0 ton
I would say if you have two units then you are covered, remember the area(region) walls, ceiling and other climate factors will play into your tonnage for you house. The best thing is to consult with a honest and reliable a/c installer in your area. i hope this helped Tim
Sep 02, 2010 | Ruud UAMB042 Air Conditioner
We have 1 ton window ac and its not cooling properly and forming ice, also its not draining out water properly
the fact that it is not draining could be the problem with it freezing up. you might have to pull it out of the window, pop the cover off and clean the drain pan so it will drain properly. also make sure the unit is level . if it still freezes up once draining properly it is probably low on charge.
Aug 27, 2009 | LG Electronic Window Air Conditioner
I need to know the BTU of our Whirlpool Air Conditioner ACQ158XSO
Th info I keep finding is 14,7000 which is just over 1 ton of cooling. Each ton is 12,000 Btu. Probably designed to cool about 400-500 square feet.
Jul 13, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
Jun 11, 2009 | Heating & Cooling
LG Electronic Window Air Conditioner Logo
146 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
