Question about Gateway FPD2185W 21 in. LCD Television
5" scratch on LCD TV
I accidentally put a 5" scratch on my LCD screen. i have gone to google and possible solutions were to used a pencil eraser or vaseline. I was going to try these until a friend told me you are not even supposed to touch the screen. what can i do?
    Brigadier General:
  • 3,006 Answers
Nothing. The only cure is to replace the screen.
Posted on Jul 03, 2009
LG 55 inch tv vertical lines, ive replaced the t-con board and cleaned the ribbons with use of an eraser and the lines continue, what is next thing to check?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 03, 2016 | LG Televison & Video
How is the process to repair scratch a LCD panel?
Wipe the area with eyeglass polishing cloth if you have it to clear any dirt/dust.
Rub the scratch back and forth with a clean pencil eraser. Avoid using the red kind and you will not have to clean off the red color afterward.
Feb 21, 2011 | Vizio 42 in. LCD TV
While i was cleaning my Sony Bravia 40 Inch 1080p Flat panel LCD Screen, it had alot of dust so i used some cloth while i was cleaning it with cloth it made some kind of lines... scratches the scratches...
only use microfiber cloth to clean LCD panels, and no windex. Use 50/50 distilled water and denatured alcohol, or a dedicated LCD cleaner. Small scratches are not worth buffing out as screen itself is relatively soft plastic.
Oct 19, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Scratches on my flat panel tv. can this be fixed ?
You can use a white eraser. Yes a pencil eraser. It will take several minutes. Cleanup with a moist cloth. This should remove the shallow scratches. On deeper scratches some people have used petroleum gel like Vasoline® to fill the scratches.
Apr 18, 2009 | Sylvania Televison & Video
Scratched Finish on Screen While Cleaning
Here are some solutions to consider. Try in an inconspicuous place first.
1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
3)You may also get commercial LCD scratch removers on the 'net.
An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
Mar 13, 2009 | Sony Televison & Video
Sctratches on 46" lcd tv. Two of which is noticeable in dark scenes.(White lines) How do I fix this?
used thse methods myself
Vaseline Method
  1. Clean the surface of the screen.
  2. Take some Vaseline and fill the scratch with it.
  3. Gently wipe off the excess Vaseline, being careful not to press too deeply so as to leave some inside the scratch.
  4. Voila. This works because the optical density more closely matches the LCD face than air.
Pencil Eraser Method
  1. Find a pencil with a clean, soft eraser. It must have no pencil graphite on it as you won't want to smudge that on your monitor.
  2. Lightly rub the eraser over the scratch or nick on the screen.
  3. Keep rubbing until the scratch completely disappears
Oct 01, 2008 | Televison & Video
Scratched lcd screen - 52inch sony bravia
Vaseline Method
  1. Clean the screen
Neither is a perfect fix but does help alot
LB
Sep 21, 2008 | Televison & Video
Scratches in my LCD Television Screen (sony bravia) How will I fix this?
Easiest solution is the stuff you buy to fix your glasses with (Lens cpr), so long as it's a small scratch. Larger scratches don't try to fix you can damage the screen further.
Other solutions (though I recommend only at your own risk)
Vaseline Method
Keep rubbing until the scratch completely disappears [1].
Sep 02, 2008 | Televison & Video
Repaire scratches on a lcd flat screen
The eraser method is even better than I first thought.
I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
-So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
Apr 25, 2008 | Computers & Internet
Surface scratches to LCD screen
ive tried the vaseline method (petroleum jelly) and you must be sure not to apply too much on the screen or else it will smudge around the scratch and it is hard to buff out, but if you fill the scratch in and wipe off the excess around it, then it should be barely visible.
Oct 17, 2007 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
163 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
