I NEED TO CLEANING MY DRUM BECAUSE THERE IS ALWAYS MESSAGE TO CONTACT CALL CENTER
SOURCE: replace drum cleaning blade
take the toner hopper off take dev unit out lower handle on umber one unit remove screw in drum pin remove primary charge assy remove screw lower right of drum frame remove screw upper left frame un plug connectors unit slides out
SOURCE: need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
SOURCE: cleaning a dirty drum
if its asi drum use braso if its opc use small amount of alcohol based cleaner be carefull
SOURCE: repeating white spot deletion suggests drum, fuser
Fuser doesnt sound like your problem generally speaking fusers will add black marks not deletions look to your image creation lense mirrors erase lamps or defective charge grid
SOURCE: How do you change the cleaning blade and drum in
why do you want to change the drum, the drum goes about 5 000 000 copies and its too expensive.
The drum cleaning blade goes about 150 000 copies and to change him on your own you need service manual.
For service manual write me on [email protected]
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
This unit does not have a drum to clean
What error message is stating that?
It should have a n alpha and numeric code to it.
