Question about Microsoft Xbox 360 Console
Broken wires copper wires in the ethernet port on xbox 360
I went to sign on to live and instantly it said there was no connection. after trying many things i finally looked inside the ethernet port on the back of my 360 an many of the little copper wires that make the connection to the cable are completly broke off, it seems to me i am the only one who has this problem. i think my brother sabatoged it so i couldnt play online. does anybody know what i could do to fix it my self or a cheap alternative to get back on line without have to send in the box?
    Problem Solver:
  • 7 Answers
If you set up a wireless router from your modem, you can just get the wireless adapter for the 360 and connect that way....I suggest a deadbolt on your door though
Posted on Jul 03, 2009
  • 508 Answers
Make your brother fix it or you will break something of his!!! :)
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    Not connecting to internet
    I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
    Jun 07, 2010 | Video Game Consoles & Games
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Can not connect to xbox live,all plug in to the router
    you either ethernet port is probably broken this happend to me recently and i could have sent it in for 99 buck or get a wireless adater so i got it from my friend and the wireless adapter works, because it bypasses the ethernet port and wirelessly connects to your network and xbox so try that out but dont buy it borrow it and make sure it works
    Dec 31, 2009 | Microsoft Xbox 360 Elite Console
    Gigafast ethernet won't let my Xbox connect to live
    You might open this ports to the Gigafast Ethernet router :
    TCP 80, 3074 and 53
    UDP 88, 3074 and 53
    Note: You'll needing to open these ports to the virtual server or port forwarding under advance settings of the router.
    Mar 06, 2009 | GigaFast Ethernet Gigafast 10/100, 8-Port,...
    Xbox 360 ethernet port -not working usb??
    no the xbox doesnt work with the usb to ethernet adapter. i thought it would work also. and it turns out it does. this would be because you have to install the device drive for it to work, and you cant do this on your xbox. but radioshack sells ethernet ports for about $6 if you know how to switch them out.
    Jul 25, 2008 | Microsoft Xbox 360 Console
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Xbox live
    2 Solutions-----
    Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
    This will probobly be free, but if your charged, it will be a small fee.
    Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
    Results should come up (for wired router)
    Network Adapter - Wired
    Wireless Network - (Left Blank)
    IP Address - Confirmed
    DNS - Confirmed
    MTU - Confirmed
    ICMP - Confirmed
    XBOX LIVE - Confirmed
    NAT - (either moderate, opened, or strict)
    If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
    If results come out to be
    ''Network Adapter - Disconnected''
    After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
    Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
    If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
    Sorry it took me so long to explain that, but i hope it helps you.
    Best of luck
    -Erk
    Jun 18, 2008 | Microsoft Xbox 360 Console
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Cannot sign up for xbox live
    have you tried running the troubleshooter (if so, wat did it say?)
    Apr 13, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    124 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
