Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC210c Repetitive Paper Jam
I have just moved and was very carefull with this printer. I put it back in the original packaging & added extra bubble wrap around it iniside the orginal box & then packed it around clothes in a plastic tote container.
Now every time (dozen times in a row at least so far) that I have tried to print, it brings the paper up from the tray right up to where the ink is sprayed and jams there. I open the back and pull the paper out, then close it up and try again and does the same thing. The real Bonus is that if I leave the jammed paper alone where it is located & Shutdown or unplug it, Then when it powers back on then it Ejects the "jammed" paper out the front and this process has happened each of the four times that I have done it. --- I am about ready just to buy another printer ... already started online shopping for one.
Any Substainal Help would be Appreciated, eh?
  • 390 Answers
Hello Elihu10,
Your paper jam may be caused by either a small piece of paper stuck in the paper path, or more likely during the moving process the removable rear paper path piece was somehow knocked loose and is not fully seated and locked into place. It has 2 tabs on it, just squeeze the tabs and remove this item from the printer, check for any obstructions, then just push it back into place. Hopefully it is now all fixed!
Good Luck!
Rich Lilja
Posted on Mar 11, 2017
  • 121 Answers
SOURCE: Brother HL-2040 printer
if someone directed you to take the printer apart, there's probably a panel or door that isn't closed or in place all the way.  Take it all apart again and start over.
Posted on Oct 27, 2007
  • 33 Answers
SOURCE: brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Posted on Nov 02, 2007
  • 188 Answers
SOURCE: paper jam
Here is the most important thing to understand about paper jams in any printer....
The printer does not know if there is a paper jam anywhere in the printer.
What it does do, is respond to sensors ( optical sensors, either open or closed, by plastic flags). These flags are moved as paper moves through the paper path.
One example of a paper jam message when there is really no paper jam, is when the feed rollers are worn and do not pick up paper from the paper tray.
When you start printing, the printer expects that first sensor to open ( paper passes the sensor ) at a very specific point in time. If the paper did not get picked up from the tray, then the printer will ASSUME that the paper must be jammed somewhere because it did not reach it on time.
Now this will also happen if in fact the paper did get picked up and then jams prior to the sensor.
So... if you get the picture of how this works, understand then too, that if the printer is showing a paper jam message at power on, then one of the flags is open when it should be closed.
If you do not actually have a piece of paper holding this flag in the open position, then the flag is possible broken.
I usually see this kind of damage occur after a true paper jam, where the paper is removed either in the wrong direction ( pulled out back the way it was going instead of the way it should normally travel ), and this breaks the flag, or it was pulled out forcefully again, catching on and damaging the flag.
All of the above pertains to ANY printer, and not just yours. you must take care to fully inspect every inch of the paper path, from the paper tray, to the exit, use a flashlight, and look for the sensors and make sure they are not blocked or broken.
Good luck,
Posted on Nov 06, 2008
  • 133 Answers
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
Posted on May 23, 2009
  • 13433 Answers
SOURCE: Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 11, 2009
What does error 73 mean? the display keeps giving that error... i have a brother mfc490cw
It is my pleasure to guide you.
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feed Problem.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us"
Good luck and please post back that you are successful or that I can be more helpful.
Jun 09, 2011 | Brother MFC 490cw Color Inkjet...
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to clear paper jam copier printer
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To resolve this issue, please follow the steps listed below:
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it. Be carefull not to touch the feed roller.
3. Remove the paper tray feeder from the front and look inside for bits of paper and check the paper is flat in the tray.
4. Replace tray and back cover and all should be fine.
Sep 21, 2010 | Brother DCP-330C All-In-One InkJet Printer
MFC210C wont print yell or blue only blk &mag. HELP!
Pull the cartridges out and them turn it off and then turn it back on then try placing them back in...Because the cartridges work on suckion.
May 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Need output paper support for brother mfc210c
Output paper support for the printer are sometimes not included on the package. You may try to visit your local retail store or check out brother sales department to purchase a compatible output paper support for your printer
May 06, 2008 | Office Equipment & Supplies
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Feb 10, 2008 | Brother HL 1440 Laser Printer
Paper jam
see here:
Sep 17, 2007 | Brother MFC-440CN InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
64 people viewed this question
James Cagle
James Cagle
Jim Keysor
