Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Starter trouble when i turn the key to on position the starter engages when turned to start it stops. have a new ignition switch made no difference is a cub cadet switch.
  • 143 Answers
Either you are using the wrong switch or the wires going to the switch are in the wrong places. You cant tell by looking at it, you must make sure you have the correct switch for your machine.
Posted on Jul 03, 2009
My car wont turn over everything works in side and rear lights new battery alterator starter and cyl and new commutateur
Define won't turn over ? There are two different situations you could be trying to discribe . When you turn the key to the start position does the starter engage an spin the engine , but does not start an run ? Or when you turn the key to the start position it won't engage the starter an spin the engine . We have a engine cranks no start or a no crank no start . And what is this commutateur ????? commutator for what ? And it also makes a difference on what make , model and year vehicle it is .
and cyl ????? what cylinder ? Ignition ,key lock ????
Aug 29, 2017 | Cars & Trucks
No start
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
Please visit website below:
http://www.cv-performance.com/harley-diagnostic-trouble-codes/
Good luck
Mar 23, 2014 | 2011 Harley Davidson XL 1200N Nightster
Battery ok no ignition
For a posible prime suspect please visit the webside below:
Harley Diagnostic Trouble Codes
Good luck
Mar 21, 2014 | Harley Davidson XLH Sportster 883 Hugger...
2006 1200 portster new battery new starter wont start or turn over
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Jan 06, 2014 | 2000 Harley Davidson FLSTC Heritage...
2006 Ford taurus won't start, starter, altlernator, battery replaced, ignition starter switch, neutral safely switch changed, still nothing
I looked at info for your security system, it is starter motor disable. I didn't see 06 ford Taurus in my database, so I looked at 05.
Battery has a full charge and battery connections all good?
We can usually do some tests to see if starter motor will crank the engine, but, if the security is the problem, it still won't start.
You can check for applicable trouble codes? Try a different key?
Feb 16, 2018 | 2006 Ford Taurus
Ignition
he ignition switch generally has four positions: off, accessories, on, and start. Some cars have two off positions, off and lock; one turns off the car, and the other allows the key to be removed from the ignition. When the key is turned to the accessories position, certain accessories, such as the radio, are powered; however, accessories that use too much battery power, such as window motors, remain off in order to prevent the car's battery from being drained. The accessories position uses the least amount of battery power when the engine is not running, which is why drive-in movie theaters recommend that the car be left in theaccessories mode during the movie.
The on position turns on all of the car's systems, including systems such as the fuel pump, because this is the position the ignition switch remains in while the car's engine is running. The start position is spring loaded so that the ignition switch will not remain there when the key is released. When the key is inserted into the ignition switch lock cylinder and turned to the start position, the starter engages; when the key is released, it returns to the on position, cutting power to the starter. This is because the engine runs at speeds that the starter cannot match, meaning that the starter gear must be retracted once the engine is running on its own.
Either the ignition switch or the lock cylinder may fail in a car, but both circumstances have very different symptoms. When the ignition switch fails, generally the electrical wiring or the plastic housing develops problems. The car may not turn on and/or start when this happens. Also, the spring-loaded start position could malfunction, in which case the starter will not engage unless the key is manually turned back to the on position.
When the lock cylinder malfunctions, however, the operation of the key itself will become problematic. If the tumblers become stripped, the lock cylinder may be able to turn with any key, or you may be able to remove the key when the car is on. If the tumblers begin to shift, the lock cylinder may not turn. Sometimes the key can be wiggled until the lock cylinder turns, but it is important to remember that this is only a temporary fix.
Replacing an ignition switch can be tricky business, particularly in newer cars, because of the anti-theft devices used in cars. Once the ignition switch is separated from the back of the lock cylinder, the car can be started with a screwdriver, making it vital that this switch be difficult to get to. It is important to consult a shop manual before attempting this kind of repair, as the anti-theft devices may require special tools; attempting to remove an ignition switch without the proper tools can render the car inoperable.
increase engine horsepower
Jun 02, 2012 | Volkswagen Transporter Cars & Trucks
Diagnosing starter problems with 1995 heritage softail classic won't start, charged battery- now no power when I turn ignition on
May 06, 2012 | 2000 Harley Davidson FLSTC Heritage...
2003 Chevy Impala 78,000 miles KEY WILL NOT TURN. - Car was running fine! - Turned off key. - Tried to restart and Key will Not Turn. It was jammed in the OFF position. - I removed ignition...
ur still in a security lock out with ignition[ key ] system u might have to have it towed to dealer for them to hook up vehicle[contact dealer and advise what is happening and also recheck new key] for reprograming or reset system..some vehicles if u try to start vehicle while in a security mode can get completely locked out of vehicle and if u replaced the whole ignition housing and not just the cylinder the housing is the reader the wiring that is around the housing cylinder tube is what reads the key and syncs with the vehicle if u put in a different one or the wiring is damaged vehicle wont start and will stay in security mode
Jul 02, 2011 | 2003 Chevrolet Impala
As soon as I turn the key to the on position, the engine turns over
The problem is either in the mechanism that pushes the rod that activates the ignition switch from the key lock cylinder, or the ignition switch is defective.
Sep 29, 2008 | 1988 Jeep Cherokee
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
246 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
