Home | Dometic | Rooftop RV Air Conditioner | Replacing a fan mot...
Dometic Rooftop RV Air Conditioner
Problem for Dometic Rooftop RV Air Conditioner
Replacing a fan motor in my Duo Therm air
By hmsajl on Jul 03, 2009
Replacing a fan motor in my Duo Therm air conditioner. Came with a capacitor that is smaller than original. Is this ok?
Sponsored Links
Solution #1
posted on Jul 03, 2009
Not Rated)
jeffmyers_20
Rank: Guru
Rating: 96%, 66 votes
It should not be a problem. Check the side of the capacitor and it should have a Microfared Rating on it. It has a symbol the looks like uF and then a number. Most of the fan capacitors are 7.5uF or microfareds. If it is the same or similar, then there is no problem.
Rate me!!
Was this helpful?
Yes
No
Popular Solutions for Dometic Rooftop RV Air
Questions and Unsolved Problems for Dometic Rooftop RV Air
Do you recommend Dometic Rooftop RV Air Conditioner?
Answer
Answer
I am trying to find the specifications of my Dometic Quick Kool Duo Therm Model 80611442 - its on a... (More)
Answer
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a... (More)
Answer
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches... (More)
Answer
Dometic 630516.331, frequency spikes with both A/C & Heat pump
Answer
need thermostat wiring diagram for duo-therm heat strip
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dometic Rooftop RV Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
