Question about Motorola TalkAbout T5900 (14 Channels) 2-Way Radio
I have t5900 talkabouts - one of the radios will recieve but not transmit - how do I fix? The second one works fine.
  • 508 Answers
Buy another one online for cheap!
Posted on Jul 03, 2009
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Motorola talkabout 101 radio user
Here is a link to the user guide http://shop.giantintl.com/Manuals.asp?offset=30
You can also contact customer support at http://shop.giantintl.com/contact.asp
Oct 12, 2013 | Motorola Talkabout 101 2-Way Radio
T5900manual
Here's an online copy on Motorola TalkAbout T5900 2-Way Radio user's manual:
http://www.motorola.com/mdirect/manuals/T59xx_User_Manual_E.pdf
Jun 27, 2011 | Motorola TalkAbout T5900 (14 Channels)...
How do I unlock the channel on T5900? I want to reset to channel 9 and it's stuck on 4
According to the manual, you want to press and hold the menu button for 3 seconds. That will unlock the keypad so you can change the channel.
May 05, 2011 | Motorola Talkabout T5720 (7 Channels)...
Issues with Motorola TalkAbout T5900 (14 Channels) 2-Way Radio. Do they need FCC programing & licensing to operate? Because I can not get the to communicate with each other!
Yes they do.The thing about the talkabout is that they work according to the network area they are connected to and the number of the talkabout they are also connected to.So all you need do now is to take the talkabout to motorola shop so that they can confrigure it for you.
Jan 22, 2011 | Motorola TalkAbout T5900 (14 Channels)...
ONE SET WILL NOT RECEIVE.OR THE OTHER SET WILL NOT TRANSMIT
You need to verify you have the frequency, code and Qt filter set identically. Also, check your batteries to see if they are good.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T59xx_User_Manual_E.pdf
You should be able to set the radio back to a simple setting with the code and Qt filter shut off (zero), this would tell you pretty quickly if your radio will communicate. If they will not communicate with the frequency set the same, and the other features turned off, you have a battery or radio problem.
Best regards.
Mar 08, 2010 | Motorola TalkAbout T5900 (14 Channels)...
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
Motorola TalkAbout T5900 (14 Channels) 2-Way Radio Logo
142 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
