Question about Minolta Office Equipment & Supplies
We keep getting the trouble code C 3822. We cannot
We keep getting the trouble code C 3822 on our Konica Minolta bizzhub C650. We cannot book a call every day to fix this. can anyone please supply me with a solution ASAP so we can do it ourselves?
    Problem Solver:
  • 14 Answers
You likely can't fix this yourself. Konica does list a solution addressing this issue but it will require a firmware update to your machine. There may be other causes as well. First be sure you don't have any HVAC vents aimed at the machine (particularly the exit side of the machine) as this is a fuser temp related service code. Contact an authorized Konica Minolta dealership and ask if they can update your firmware for you.
Posted on Jul 07, 2009
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 01, 2017 | Konica Minolta BizHub C650 Copier
My konica minolta printer C650 series PCL has an error code of C-3425
Sir/Mam, turn off the main power switch(INSIDE), ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Aug 19, 2015 | Konica Minolta Office Equipment & Supplies
HOW DO I ESCAPE ERROR C-2A01 FROM MY KONICA MINOLTA C650
C-2A01 is for the cyan toner not the imaging unit. The unit is having trouble reading the counts. Try replacing the Cyan toner and let me know how it responds after.
Feb 16, 2015 | Konica Minolta Office Equipment & Supplies
C650
scanner home position code. Check the scanner located under the big glass. the scanner also has the exposure lamp. the bright light.
Jun 26, 2014 | Konica Minolta Minolta DI1610P Printer,...
How to fix error code 1327 on minolta bizzhub 250
Looking thru the service manual could not find code 1327?
Apr 08, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub c650 fehlercode c3102
C 3102 - Communication sistem setting error.To reset :
Turn OFF the copier,keep pressed Utility/Function key and turn ON.Keep pressed the Utility key when Trouble reset message apaire on screen.Touch the message,turn OFF ,wait 1 minutes and turn ON.
If the code persist remove the fusing unit and under fuser unit in right side upper is located 2 sensors under plastic knob.Clean the 2 sensors.
Dec 22, 2013 | Konica Minolta Office Equipment & Supplies
Code erreur c3b04
what solution for the trouble code c-3B04 for c650
Apr 01, 2013 | Konica Minolta BizHub C650 Copier
Konica Minolta c650 Bizhub Address Book Questions
no all you get is the square buttons on the screen and they are shown in the order that they are entered
Mar 02, 2009 | Konica Minolta Office Equipment & Supplies
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
967 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
