Question about Zenith Z25X22S 25" TV
Need manual for zenith z25x22s - Zenith Z25X22S 25" TV
Need code for a 1997 Z 25 X 22S Zenith TV .
Have the remote , bought used tv , but remote is not working . It has a prgram buttom on top left of remote
Posted on Mar 15, 2011
Zenith 25" model z25x22s has hardly any green
Check the green output section circuit at the video output card for any loose soldering. This card can be located at the neck of the picture tube itself, will directly plugged to it. You can pull it out of it for repair. Re-solder all the suspected solder terminals there.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 16, 2013 | Televison & Video
Remote control codes for a z25x22s tv
The universal remote codes for Zenith TVs are 0000 or 052.
Mar 15, 2011 | Zenith Televison & Video
Where is the vertical adjustment knob on the Zenith Z25X22S and how do I get to it?
many new TV's having vertical hold most of the case you need service mode to change the setting
Aug 24, 2010 | Zenith Z25X22S 25" TV
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
Programming stock remote
Most original remotes are non-programmable. I would get universal for $5-10
Jun 11, 2009 | Zenith Z25X22S 25" TV
Zenith tv, video retrace lines.
how is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Apr 28, 2008 | Zenith Z25X22S 25" TV
Programming high number cable channels
on your remote there is a menu button press that and do a channel search it should fix the problem
Feb 16, 2008 | Zenith Z25X22S 25" TV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Televison & Video Logo
262 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
