Before you can download pictures to your computer, you have to install the software that came with the camera. On older operating systems, on the CD will be the driver you need, so the OS recognises what you are connecting to the USB connector. From Windows 7 and up, the driver will be in the OS and the computer will recognise the camera, after you with it on. But be aware as long as the USB cable is in the camera, you won't see a thing on the camera. Lots of camera's ar also charged through the USB connector, so unless the camera gets a signal you are connected to the computer, it won't start communicating, so it looks like nothing is connected.
If the camera won't turn on, after you pulled out the usb cable (from the camera) please first charge the battery first.
Then try again.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Nothing is wrong. The file names of the recent pictures probably duplicate those of your old pictures. Your computer is probably caching the images associated with those names until you double-click on them.
Since you declined to specify the type of computer and the software you're using, I'm afraid I can't tell you how to clear the cache. I also assume you're not really connecting your 35mm SLR camera to your computer.
When you take pictures without the internal card , they get stored inside the camera internal memory (usually 8 or 16 MB only).
Connect the camera to a computer using a data cable, without putting any memory card inside the camera. The camera internal memory will be displayed as a new external usb disk on computer.
i do not think the computer had anything to do with it. There are many reasons for fuzzy pictures
camera movement or shake- be very gentle when you push in the shutter
always focus your pictures by pushing the button half way down then slowly pushing it all the way down
Make sure you have your camera set on the right mode for the scene
Make sure you are not too close to the subject.
If you have changed anything on the camera go back to the menua dn change back to the default settings.
----Just a note:
When you connect to the computer you connect to the PC USB port first >then the camera port>then you turn the camera on and reverse theorder when you disconnect.
Install camera driver to PC.
Connect camera to the USB port at the back of the CPU of your PC.
Turn on the camera.
Select Computer on the screen of the camera.
Go to My Computer.
Click Removable Disk.
Click DCIM.
Click 100SSCAM.
IF there is no Removable Disk in My Computer, go to Device Manager and look for Unknown Device and click on it.
