Question about Intuit Quicken Deluxe 99 for Windows (quicken99)
Got a new computer. reloaded quicken99. how do i import my old files from the hard drive
    President:
  • 1,383 Answers
It should be okay to Delete the Quicken Folder. Any Shared file would be in the "C:\Program Files\Common Files\" folder or sub folder(s). There might be a file in the root directory named "Billminder.exe" this is also a Quicken file you'll want to get rid of. If it is there, you'll need to edit the Autoexec.bat to delete the line that points to billminder.exe.
Aslo try to first copy your quicken software folder from c://program files /
and paste in your new computer c://program files/
then check.thee should be 1 data folder which u need to take it and repalce with new
Posted on Jul 03, 2009
How to reboot my Dell computer optiplex gx400 version 1.10 and
This machine is ancient (in computer terms). If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to reload the old computer, and if that works, copy your personal files back to your newly restored computer, otherwise you could copy your personal files to a newer computer.
Jul 29, 2014 | Computers & Internet
Files from a back up
You should be able to plug the external hard drive into the new computer and restore. Generally the drivers needed to access the external driver are on the external drive itself. The operating system will detect the hard drive (if it has plug-and-play services running). If the new computer fails to see the external drive, check the cable and download the driver manually from the manufacture's website. If the drive is recognized by the operating system, but you do not see a prompt to restore from the backup, you may need to locate a setup program on the external hard drive to start the restore process.
Apr 18, 2014 | Computers & Internet
Transferring files via external hard drive to new computer
You just need to connect the external hard drive to the new computer. Once it has connected and Windows recognizes the drive it should pop-up with the window asking what you would like to do (select the option to View Files). Also at this time open the folder on the new computer that you want to store the back-up files in. Make the external hard drive folder and the new computer folder sit side-by-side. Then while holding down the CTRL button on the keyboard click each file you want to move. When you are done selecting them - right click on any of the file selected and on the pop-up menu select "copy". Now go to the folder on the external drive and right click the mouse again and from the pop-up menu select "paste". This will just copy the file, that way you can keep the files on 2 different hard drives in case something happen to 1 of them.
Austin
We-Supply.com
Jul 22, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
I'm trying to reload my edited videos onto a new computer - but they're no longer opening. instead it says the original files don't exist and asks if i want to relink. we saved all our videos onto our...
It sounds like the problem is with the linking between the video editing software, and what you used to make the video originally. When you import things like pictures and videos into the software, it just takes the path to the videos (such as C:\\Program Files) When you move the software to another computer, that path is changed and the videos(original files) are no longer where the editor thinks they are. If you still have your old computer, get on it, and either export or publish the video as a video file (such as .mp4 or .wmv) These aren't linked to the original files, and should transfer easily. Hope this helps!
Mar 28, 2011 | Corel Video Studio Pro X2 for PC
Hi, My previous computer died and I have tried to
you need then to "boot" in the second HD to TRY to look at those files.At start up press F12 and chhose the HD.
Oct 12, 2010 | Western Digital Caviar SE WD2500JS...
My laptop is running slow should i use recovery disc to wipe it clean,nothing really important on hard drive
if u dont have nothing important, then just re-format it and reload Windows
recovery disk will not load OS..u will need win OS install CD
Jan 22, 2010 | eMachines T3508 PC Desktop
I have an old sony vaio with a 60 gb hard
How "full" is the hard-drive? Perhaps, you could have only a few gigabytes to be "saved".
Click Start
Click My Documents
Click Edit
Click Select All
Right-mouse click on any of the highlighted items.
Click Properties.
Windows will report on the size (megabytes/gigabytes) of all the selected documents and folders.
Perhaps, you can buy 4GB or 8GB or 16GB USB memory-stick,
and manually copy your 'My Documents' files/folders to that memory-stick.
Or, use the "Windows Files and Settings Transfer Wizard" to "collect" all your files & E-mail, and write an "export" file to that memory-stick.
Then, on the "new" computer, run the same Wizard, and "import" from the USB memory-stick onto your new computer.
Dec 31, 2009 | Mirus (SITL51C410) Notebook
When the machines start up, it freezes except in safe mode.
There are a lot things to consider here before anything is done..
1. How important is the data on your hard drive? Is EXTREMELY important or sort important or " Who Cares Important"? If it is extremely important, take the hard drive out and replace it with a new hard drive of your choosing.
2. Then reload a FRESH OPERATING SYSTEM on the new hard drive, virus protection, word processing and all the other programs you have.
3. After you have the machine rebooted up with a NEW OS on the New Hard Drive, buy a connector cable and connect your old hard drive to a external port, and treat the OLD DRIVE as a EXTERNAL DRIVE and copy over to the New Drive, all your Important data.
I have not a clue what caused your machine to dump its Boot Sector or what else... But the key is to not fool with the EXTREMELY IMPORTANT data on your machine. It would take you months, or years to replace it, if it can be replaced at all.
From this lesson, I suggest you learn how to backup your hard drive Daily, Weekly, Monthly; and the interval you choose is dependent on what you use your machine for. Obviously monthly is the bare minimum.
Let me know if this helps you,
Kindly,
Jim
Dec 20, 2009 | Toshiba Satellite M35X-S149 Notebook
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
I have reinstalled quicken deluxe 2000 after my hard drive crashed.This has been repaired,All The previous quicken accounts programme has been stored on the d drive. I do not know which quicken files to...
In the C drive Navigate to View menu and choose option "Details"
Now you can see the Created Date for specified files so that you can check which files are older / newer
May 27, 2008 | Intuit Quicken Deluxe 99 for Windows...
Computers & Internet Logo
47 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
