Question about Nova Scrapbook Factory v.3.0 Deluxe Image Collection/Management - PC
My scrapbook factory delux version 3.0 wont work on my new laptop with windows 7. Is there an upgrade or other solution as my usual computer stores don't sell any card making or scrapbook soft
I had to get a new laptop with windows 7. When I put the discs in it didn't work. My computer shops in Sydney don't sell any Card making or scrapbooking software. could you advise me please of my options? Thank you.
    Sergeant:
    Champion:
  • 234 Answers
Check to see if there is an update for it.
Posted on Sep 20, 2014
SOURCE:
My Scrapbook 2 by Ulead will not open using Windows 7
This version of the program was released for XP. If you have Win7 32-bit, try the compatibility mode. If you are installing the program, choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the Ulead My Scrapbook XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. Also your printer can only be installed on the virtual computer or the real computer at any given time. You will be asked to uninstall if you try to install on the other.
The other option is to upgrade to the Windows 7 compatible version. I believe that the Scrapbook is now part of PaintShop Photo Express: http://www.corel.com/servlet/Satellite/us/en/Product/1235746620575 .
I hope this helps.
May 22, 2011 | Ulead My Scrapbook 2
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
I recently upgraded to Windows 7. I went to install this software again but says that it is not compatable with the drivers. How to install this?
Windows 7 has a "Program Compatibility Wizard".
Launch this Wizard, and tell Windows that you want to install a Windows XP application.
Point to the CD-ROM containing the software, and install it.
Dec 17, 2010 | Nova Development Art Explosion Scrapbook...
Is there an upgrade (besides buying version 5.0), or some other way to make this software compatible with windows 7?
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Dec 05, 2010 | Nova Development Art Explosion Scrapbook...
I have Photo explosin 3 on my computer it will not work correctley I have windows 7. It keeps freezing or not opening,
Hello!
I'm Richard from SoftCity Cafe, the new home of Photo Explosion's tech support. I spoke with the tech support reps about PE 3 and its compatability with Windows 7. Unfortunately, only some aspects of the program work in Windows 7 and the recommended solution is to upgrade to version 4. I can tell you that there has been a request of the PE development team to release a patch for Windows 7 compatability, and if this is something you are interested in I would recommend leaving a message in this thread on SoftCity:
http://cafe.softcity.com/questions-answers/view/1cDMxMzN/please-help-photo-explosion-deluxe-version-3-is-much-better-than-version-4
Hopefully this will help you and users like you.
Cheers,
Richard
Sep 07, 2010 | Nova Development Photo Explosion Deluxe...
How do I get Photo Explosion Deluxe Version 3 to
I am still not sure if they have a fix for Windows 7. I know they have brought out a version 4 which does work with Win7 but here is a link to the upgrade drivers they do have
http://www.novadevelopment.com/support/updates/
Jan 10, 2010 | Nova Development Photo Explosion Deluxe...
Upgraded from windows vista to windows 7 and and I am told photo explosion deluxe version 3 is incompatible with windows 7. what can be done to make it compatible?
you should contact the manufacturer because they have produced a version 4 which is compatible with Windows 7 see the link below. The company was saying they were working on a driver to fix the compatibility issue with version 3 but they obviously have one.
http://www.novadevelopment.com/software/photo-explosion-deluxe-129012
Jan 09, 2010 | Nova Development Photo Explosion Deluxe...
I can not get my pictures to upload to scrapbook factory deluxe 4.0. It worked on my old computer windows xp, but will not work with my vista. Can someone help me?
go to windows update and check for software update's,seam's you have a compatability issue with the earlier software, i know xp has a compatability program that lets you run programs in a earlier os formate to make the earlier programs run in the later OS'S Hope this works Steve
Oct 01, 2009 | Novatel Art Explosion Scrapbook Factory...
Nova Scrapbook Factory v.3.0 Deluxe Image Collection/Management - PC Logo
135 people viewed this question
Top Nova Computers & Internet Experts
 Grubhead
Grubhead
Jay Plesset
Bill Boyd
Are you a Nova Computer and Internet Expert? Answer questions, earn points and help others
