Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Fails to ignite - fan blows for 15 seconds, then 2
Hayward fails to ignite - fan blows for 15 seconds, then 2 scond blast of hot exhaust, the off then repeats until IF
I had the same problem it turned out to be an old regulator valve on the gas meter wasnt allowing enough gas to reach the heater. i had to have the gas comapny come out. they changed it for free.
Posted on Aug 01, 2009
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Buel blast just quit running
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and free downloads that you need please visit the websites below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Thread 2006 Buell Blast stopped running
http://badweatherbikers.com/buell/messages/3842/143909.html
Buell Service Manuals PDF Download
TWIN Motorcycles Buell parts
2001 Buell Blast Owners Operators Owner Manual Factory 2001 eBay
Aug 15, 2013 | 2003 Buell Blast
2001 buell blast runs until hot then backfires then wont start
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and free downloads that you will need please visit the websites below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.badweatherbikers.com/buell/messages/20164/150578.html?1444533833
Ignition Coil Testing
May 05, 2012 | 2001 Buell Blast
Buell blast that turns over but wont stay running
http://www.buellxb.com/forum/showthread.php?31223-Blast-has-trouble-starting-and-won-t-stay-running-unless-you-throttle-it
2008 buel blast wont stay running
Mar 18, 2012 | 2006 Buell Blast
2002 blast 500 starts an only runs about 4 min an stalls an wont start back up it may start the next day
Hi, Mdtrikeman the following applies to carbureted also fuel injected models and the usual suspects are:
Buell Blast Motorcycle Forum 2000 Buell Blast Stalls When Idling BadWeB
http://www.buellxb.com/forum/showthread.php?42173-03-Blast-stalls-when-given-gas
Jan 03, 2011 | 2002 Buell Blast
Why does my ignition fuse (7.5) keep blowing on my 2007 buell blast?
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.buellxb.com/forum/showthread.php?10783-buell-blast-ignition-fuse
Buell Blast Motorcycle Forum Archive through March 19 2008 BadWeB
Buell Motorcycle Owners Manuals
May 10, 2010 | 2008 Buell Blast
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Minimax NT 400 TSI Heater problem
I bet that your 15 seconds of flame are more like 7 seconds. The time is very important. If the flame is not recognized after a specific time the valve is shut off. If the flame sensor is GOING bad but still make some rectification then you may get the issue you are having. I would start with the flame sensor and work from there.
May 03, 2017 | Pentair MINIMAX NT TSI IGNITER
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
262 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
