Question about Garden
How to fix the pull starter for the weed eater
  • 33 Answers
Give me make and model
Posted on Jul 04, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
    You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
    Sep 21, 2014 | Garden
    Pull cord on weed eater won't engage
    If the pull cord does not turn the engine over, the starter pawls are probably not working properly.
    Jul 13, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
    Hard to start weed eater
    check for proper starter proceedure.some models are very specific to starting proceedure.if the equipment does not run to warm up or if the chike sequence is improper it will not start
    Sep 09, 2012 | Stihl FS 85 Weed Eater
    My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
    Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
    Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
    Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
    you may have wound the spring backwards, try winding the othe way.
    May 09, 2010 | Garden
    Replace starter line on my Poulan 446T PRO Weed Eater
    Its quite a job to get to the starter, you need to remove the tube and shaft from the motor, then remove the tube housing held with three screws, once removed you will find the clutch, remove the securing nut clutch and washer, now remove the screws holding the clutch housing and remove, the starter pulley is housed in this housing.
    Oct 10, 2017 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Garden Logo
    79 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
