Question about Electrolux Guardian Bagged Canister Vacuum
It's an old cannister electrolux vacuum cleaner and it's not worth to have it serviced. The motor is noisy it appears to be obstructed but I can't open it since I don't see any screws. Would you please tell me how to do it. Thanks Ray
  • Jon elux May 11, 2010
    I need to know the model letter or number, if it is an old rounded metal canister, tell me the color and if down near the bottom (hinged side) of the bag door there may be a model designation, if it is one of the newer rectangular models, the model number will be on the inside side of the bag door. The oldest models will likely have a plate on the bottom with the designation. Usually the electrolux's were built all with screws, often hidden behind little doors for other things or under tool clips, switch covers, or bumpers. Again, describe or post a pic of the vac itself for me and I can tell you. Thx, Jon
  • 430 Answers
You will need to peel the soft rubber bumpers away from the side, like pealing a banana. Grip the bumper tabs with needle nose pliers from the bag area with door open. Underneath will be a set of locking keys which slide forward ONLY out the front of the machine. Once they are removed the front of the vac will scissor open allowing the rear housing to drop off. This is normally done in a cradle in a shop. Tag your wiring harness before removing the motor. The motor slides up out of keyed slots. replacement is the opposite.Rubber O ring is a motor seal and must be clean and properly aligned. Motor MUST reinstall with housing in slots. Check your fans for dirt and bearings for replacement. 8mm shaft size 108 bearing???
Posted on Sep 07, 2009
  • 67 Answers
There is a latch on the top of the tank right above the exhaust hole. Lift, and it will release the back 5" of the unit
Posted on Jul 24, 2009
4 Suggested Answers
SOURCE: Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
  • 70 Answers
SOURCE: I have a Model E Electrolux vacuum cleaner. Could
The model E vac was made from 1954 to 1956. The worth depends on what the vac looks like and how it runs. Maybe between $50.00 to $100.00.
Posted on Oct 22, 2009
VacuumRepair
  • 438 Answers
SOURCE: what charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
GoVacuum
Posted on Apr 08, 2010
Testimonial: " CHRIS J. GOVACUUM RESPONSE WAS IMMEDIATE. IN THE SPACE OF A FEW SENTENCES HE IMPARTED A VERY CLEAR PICTURE OF THE SOLUTION AND ADDED SOME NICE TIPS."
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
What charge for this service?
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
381 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
