NEED TO GET ANSWER MACHINE
Try dialing your phone # from the same phone that the voice mail message is on.
Another tip is you can dial 611 from that same phone and it will usually route you to their customer service who will provide more specific instructions about different ways to access VM for that particular service provider.
Remember that both of these tips only work when used on phone in question. (cell phones and land lines)
SOURCE: I need to figure out
I assume you are talking about a cell phone. The number is stored in the setup area of the phone, or, sometimes, in the telephone address book, where it was placed by your carrier during account setup. Your carrier's customer service can also tell you the voice mail number associated with your cell number. If an office phone, then the access number is your regular phone number. Just consult the manual for how to enter vocie mail from a remote call. Example: on Lucent Partner, it is *7.
SOURCE: Change voice mail/greeting
Which voicemail do you have?
dial into mail, it will say....
welcome to partner mailvs
welcome to partner vocie messaging
wem\lcome to partner messaging......
which do you have?
SOURCE: I have lost the instructions for my 6.0 phone.I
I cannot get the answering system to go to the "ON" position. Tried all advice in manual-no luck. DECT 6.0
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring
service, then set the printer to receive faxes manually (Auto Answer Off). This
setting lets you receive both voice calls and fax calls, but works best if you
use voice mail more often. You need to turn off voice mail whenever you are
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
