Question about Ricoh Aficio SP C811DN-DL Printer
The bypass tray is contantly jamming when we try to print.
  • laura_boyd Jul 03, 2009
    We are already aware of the roller situation. We have tried cleaning and replacing the rollers but that only seems to helps for a short period of time. is there any other solutions you can think of, that may help this problem?
    Problem Solver:
  • 14 Answers
Hi, i'd start with cleaning any rubber rollers in the paper path, if its picking multiple sheets and then jamming, it will need a pick roller and seperation pad, hope this is helpful ,M.
Posted on Jul 03, 2009
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
What does fault 072-210 mean? how to fix it?
An error occurred when using Tray 2. Turn the machine off and on. Most likely worn feed rollers, causing a "Ghost Jam" try replacing the feed rollers in the tray, and try again.
Jun 05, 2014 | Xerox Workcentre 5225 / Copier, With...
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
Paper Jam Konica Minolta BHC451
Is the thick 4 11 x 81/2? take the paper off the bypass tray, first send the job to the copier selecting the bypass tray the copier is going to beep telling you replenish paper in the bypass when you place the paper in the bypass make you follow the orientation of the paper on the copier screen.Might also want o replace the bypass tray roller set. If the Plain paper through Thick 3 work then you did not need to replace the main board. Are trying to duplex the paper????? When it jams where does the paper stop??
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 16, 2017 | Konica Minolta Bizhub C451 Copier Print...
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
How come i can't print on 4 3/4x6 1/2 envelopes? The envelopes keep getting jammed in the machine.
try the bypass.... if unable to print via bypass then clean rubber bypass feed rollers with alcohol... next step... see if it jams at the finisher... if so set the machine to exit from an internal tray... if it has one...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 12, 2009 | Canon imageRUNNER C3220 Color Copier
Ricoh Aficio C410 bypass tray not picking up and reporting jam
This is happening to me also. The rollers sound like they're turning, but the paper doesn't advance. I then go into th emachine and spin the roller cam a bit and it seems to clear the problem. Any idea what's happening?
Jun 09, 2009 | Ricoh Aficio SP C410DN Laser Printer
Tray 1 problems
Most machines refer to the bypass tray as tray 1. You might want to make sure there is not a jam in there.
Jul 05, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
192 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
