Reset limp mode
SOURCE: how do i get to the tappets on a 100 series turbo landcruiser
you dont i think they are just shims mesure theshims dont mix up,mesure the gap firstwrite them down then add or replace shims
SOURCE: I have a Toyota Landcruiser 80 series FZJ80, it
Petrol has a different ignition point than LPG. You might want to get your fuel system recalibrated.
SOURCE: Timing belt light of Toyota LandCruiser 2006
the reset procedure of the timing belt light is all done by pressing the trip meter button and holding it in whilst the ignition is turned to on then select from the trip button then continue pressing until you come to 15 on trip metre, turn off and then restart. The light should then go off.
SOURCE: 100 series toyota landcruiser diesel 1hz, engine
Landcruiser 100 vx, 2003 model with engine number 1HD-FTE is not starting, I've found out that the fuel pump, starter, battery are all functioning well. Where next should I look at.
