I'm a widow and I don't know what fuses or sensors to look for brake lights
SOURCE: 2004 chevy trailblazer low beam sensor
I just fixed my light problem tonight. you need to switch your relay #45 with #46 it will fix the light problem i am calling chevy in the morning to complain
SOURCE: 2004 Chevrolet Trailblazer brake light doesn't work
If the other side is working, then it will not be a fuse problem. more then likely it is a grounding problem or there is a short in the wire. Take a test light and check and see if you are getting a hot wire to the brake light. If it is hot then it is a grounding problem. Make sure that the bulb is in the right way and look for any corrosion where the bulb goes and clean it out.
SOURCE: 2004 chevy 1500 brake lights not working
check fuse under hood, batery terminals coroded wire at harness if everything fails run a hot wire to rear brake line with an interuptor.
check the swich under the foot brake.
vitally
SOURCE: chevy trailblazer check engine light
P0128 is coolant operating temperature operating too low. This can be contributed to the Thermostat stuck open or faulty electronic radiator fan clutch. This is common, I had the same issue and replaced the thermostat and fan clutch and had the clutch re-programmed (required) at the dealer. As for the P0410, check the air pump fuse, if blown it will set this code on. Also check the air pump hoses for water and cracks. Hopefully this helps!!
SOURCE: The headlights on my 2004
Headlamp relay part # 15016745 under hood fuse box , common problem.
does the third light on top still work? if it does, replace the bulbs on the 2 sides.if you still have problems, the circuit board within the tailight assembly could be bad.ive had those go bad along with some serious corrosion. good luck
