Question about Indesit Dishwashers
My indesit dishwasher just 10 months old has broken down threetimes in the last 2 weeks its overheating and could have went on fire indesit have refused to give me a replacement i will never buy anything from this conpany again
    Problem Solver:
  • 8 Answers
Probably the thermostat on the water heating element is bad.
it is made so the water heats up to 180 degrees F and turns off.
it will kick on and off to maintain the temp constant.
if it is stuck on all the time the water will over heat.
the heating unit i replaced here in naples italy because mine was broke and would never start up.
after taking mine apart i learned a lot.
the heating unit cost me 28 euro or about $40 .
if you have a 1 year warranty they have to repair or replace the unit.
if you have all the receipts call the home office and complain.
the eater heating unit looks like a peace of exhaust pipe 2 inches in diam and 8 inches long.
it has the heating element wrapped around and the thermostat on top.
hope this helps.
ralph
Posted on Jul 03, 2009
HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Mar 04, 2012 | Dishwashers
I have a 1986 toyota pick-up, 4 cyl, 4wd with a 22r engine. the truck had been overheating and I found a leak in the rad, I replaced the rad and everything was fine for the past few months. Recently it...
l could suggest you to check your engine thermostat if is working. if it is found defective,replace. some say, yes, could be the head gasket. it causes also of overheating. but smoke you notice at the tail end, could be you have broken valve seal and eats up the oil. this another problem makes the engine's overheating. the 25 old old engine really need an overhaul.
Apr 09, 2011 | 1986 Toyota Pickup 4WD
Xbox360 thinks it's overheating
Speaking from experience with my son's xbox....the thermal deal in it is bad. You can get this fixed by a shop but it will only last a few weeks to a month.....sorry to say...it's a bad xbox now.
Apr 18, 2010 | 2004 Mercury Grand Marquis
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D63 Diashwasher Trips Electrics
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes. heck your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them.
Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight.
A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Hardness (Grains) Tbsp. of Detergent
0 to 3 1 4 to 6 2 7 to 9 3 10 to 12 4
cheers!!!
Jan 14, 2009 | Indesit 24 in. D63 Free-standing...
Glasses are cloudy and rust spots on cuttlery
I had the same issue until I switched from Cascade to Electrosol. I still use the Cascade rinse solution in the door dispenser. Also use the heated dry option. The energy saving option seems to promote clouding.
Jan 10, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indersit dishwasher
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
YOU NEED SERVICE FOR LIGHTS FLASHING. This is a code signal
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
261 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
