Problem with ViewSonic Pro VP2130b (Black) 21.3 inch LCD Monitor
NEED TO CHECK FOR BAD CAPS IN VIEWSONIC vp2130
WHERE CAN I FIND INSTRUCTIONS FOR DISASSEMBLY? the stupid
post will not let me just put in my product. so i just chose a viewsonic at random to get this posted!!!!! i dislike stupid smart programs.
Posted by avatar on Jul 03, 2009
    • By avatarBuddy Mcsparrin May 11, 2010
    • Hello, To disassemble your monitor follow these steps. 1. Remove the stand, usually 2 to 4 screws 2. Now there will be screws in each corner on the back of the monitor. 3. Take a small flat blade screw driver and seperate the two halves of the case. The front and back are held together by plastic latches spaced several inches apart around all four sides. 4. After the back case is off the boards you will be looking for are under the metal shield, remove the screws that hold it on. 5. Check my web site at www.ccl-la.com , we have pictures of what the bad caps look like if you are not sure. 6. Be sure to replace any capacitors that have raised and blown tops. I hope this helps, If so please rate my solution. If you need more info let me know. Buddy Corporate Computer www.ccl-la.com
Solutions (1)
Best Solution
Buddy
Corporate Computer
www.ccl-la.com
Add Your Solution
See all ViewSonic Pro VP2130b (Black) 21.3 inch LCD Problems
