Question about OKI MICROLINE 320 Turbo Matrix Printer
Had to get new computer and change from parrellel port to ubs it is installed but will not print
    Champion:
  • 220 Answers
Needs emulation card.
Posted on Jul 05, 2009
Does anyone know if such an item exists as a PCIe x16 card, which serves as both USB3.0 Superspeed hub, along with SATA-III internal and external ports?
Sounds like a 16bit computer card to boost ubs capability from 2.0 to a 3.0 ubs port. It's dated by a few years. Every thing is 3.0 ubs now.
Sep 16, 2015 | Computers & Internet
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
Replace the ubs ports on my computer
USB IS THE CORRECT TERM TRY TO FIND AN OPEN PORT PLUG IN UNIVERSAL HUB EXPANSION PORT
Sep 09, 2015 | Toshiba Satellite Computers & Internet
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Default printer port
Delete the printer and reinstall for best results.
Aug 08, 2012 | Epson UB-E03 Ethernet Interface C32C824541...
How to change from serial communication to parllel com mode
OS settings to change port ---------------------------------------Click Settings > Control Panel > Printers and Faxes > Select your installed printer and right click on it > select properties > Ports > change serial port to parallel (COMx to LPTx)
Printer Settings to change port-------------------------------------------------Click here for EPSON user manual and refer page number 36 for printer settings. Change I/F mode to parallel (Interface mode) as instructed by Epson.
Feb 17, 2012 | Epson LX-300 Matrix Printer
I want to install the driver of my scanner Mustek 1200 UB, for xp, please help me
First, go to:
http://www.mustek.com/mustek/supportdrivers.php
Under "Category," select "SCANNER."
Under "Series," select "USB Port."
Under "Model," select "1200 UB."
Driver installation instructions for XP/Win98/SE will be shown.
For Windows XP, there are 5 separate files you will have to download (the instructions tell you this).
Also note: "Make sure the device is not plugged into the computer during the drivers install. After all the files are installed plug the device into the computer. DO NOT PLUG DEVICES INTO "FRONT" USB PORTS ON THE COMPUTER AS THESE ARE "HUB" PORTS AND the system may not "see" the device."
Good Luck!
Jan 24, 2010 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
OKI MICROLINE 320 Turbo Matrix Printer Logo
126 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
