Question about Mitsubishi WD Televison & Video
Clean the inside of the plastic screen from bugs ?
Cleaning the inside of the plastic screen
SOURCE:
bluenadas
  • 203 Answers
SOURCE: cleaning the inside of the front screen
It's not hard but is time consuming
You'll have to pull the front of the unit off to clean the inside. This includes taking out the screw that are open normally and there should be about 4 screws that are behind the bottom-back panel.
When you open the unit just be sure you get it clean the first time and don't leave any stray fingerprints on the glass. And don't touch the projection lens at all. Use compressed air to blow it off but I wouldn't recommend cleaning it unless it is just filthy and the canned air doesn't work for you.
Posted on Nov 19, 2007
drumbanger
  • 1199 Answers
SOURCE: bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Posted on Jan 22, 2009
SOURCE: How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Posted on Feb 11, 2009
ladywinn
  • 5138 Answers
SOURCE: bug between screen and plastic cover screen
You will have to remove Front cover in order to clean, remove bottom part then you should see screws holding on screen remove and clean
Posted on Sep 21, 2009
Testimonial: "Thank you very much "
SOURCE: bugs are inside tv seen on inside of screen, how
How do I remove the screen to remove bugs?
Posted on May 25, 2010
Cleaning the screen
The screen is made of plastic. It should be cleaned only with water and a damp cloth. The mirror inside the set however may be cleaned with glass cleaner, carefully as not to drip any on the boards as it will corrode connections. And the internal lenses themselves are made of various materials and typically clean well with 70% isopropyl alcohol.
Apr 18, 2014 | Akai PT4799HD Rear Projection Television
Screen seems dirty from the inside. How do you clean?
around the rim of the screen there is a plastic cover you can pull this off there are clips holding it then you can take protection screen off and clean
Oct 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
A spider is on the inside of the screen. how do I open the tv open to get the spider out and clean the inside of screen and lenses?
go_n,
First gather your needed items: screwdriver and a helper.
The screen is mounted to the enclosure of the TV by hanging on tabs mounted on the enclosure inside behind the screen. The screen simply lifts off after removing it's set screws at the bottom of the screen behind the big plastic piece that is below the entire screen.
1) Remove the speaker covers (grills).
2) Locate and remove the screws that hold the plastic piece onto the enclosure (8-12).
3) Remove the plastic cover and you will see the set screws holding the screen.
4) Remove the screws (2-4).
5) Use your helper as your screen is really big for most average sized people and lift the screen including the plastic bezel up and away from the enclosure.
Ensure that you have a secure area to set the screen as it will be large, heavy but yet very delicate. Also, do not clean anything unless you know for sure that you need to as sometimes just by touching things they get misaligned or break. This means but is not limited to: mirror, lenses & the screen.
When reinstalling the screen ensure that you hang the screen back onto all of the tabs or the picture will be blurry.
Good Luck!
-Chris
Sep 06, 2010 | Hitachi 57G500 57" TV
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
NEED TO REMOVE INNER SCREEN.
take the lower panel speaker covers off first, then tanke the 4 screws out below the screen, then take the bottom skeleton cover off around the speakers then you can take the 4 screws out of the bottom of the screen then the whole screen slides up with 4 tabs in all 4 corners becarefull not to pull out the plastic holders will break you need to make sure to slide it upwardes then you have full access to the inside to clean. hope this works for you
Dec 29, 2009 | Toshiba TZ50V51 50" Rear Projection...
Looks like I have a couple of flys on the inside of the screen
Dont even think of removing the screen.....virtually impossible to reinstall. If you must clean...clean the picture tubes. Blow the dust off the lenses with air spray, then spray a lint free cloth with a lcd, plasma cleaner. Try not to use windex. [leaves a film on plastic lens] . Now pay close attention because the mirror you try to clean is a reflective plastic sheet that can tear easily. Lightly brush a new feather duster on this. Now you can only do this by removing the lower back cover [a hard cardboard material] and dislocate your elbo to clean . You can clean the inside of screen with the feather duster, donot use a cleaner inside the screen or mirror. Relocate the old elbo and replce the lower back cover.
Aug 25, 2009 | Philips 55PW9363 55" Rear Projection...
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Screen
yes you can remove the screen by removing the front plastic trim and the removing the screws that hold the screen in. clean the screen and put it back together.the front plastic trim should just pop off
Aug 30, 2008 | Sony KP-51HW40 51" Rear Projection...
52" rca model #p52930bl
The plastic screen itself never gets dirty on the inside, unless a spider has taken up residence nearby. What you are likely experiencing is dust built up on the CRT lens and mirror - which would cause the picture to look dull with low contrast and brightness. If that is the case, you may find on your model that the screen either pulls out or that there is a wood piece at the bottom that is hiding some screws or maybe the speaker grill needs to be removed to expose said screws. Be gentle cleaning the mirror, as it is surface coated and could be scratched easily.
Dec 26, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
