Sony Vaio VGN-FE550G Battery Power Probs.
We are dealing with a Sony Vaio VGN-FE550G. The basic problem is that my laptop won't run off battery power anymore. It will charge the batteries and recognizes them, but when I take the power cord out it shuts off and doesn't switch to battery power.
This started when I did the battery recall for the system and the new battery worked for a month then it started doing this after I accidently kick the AC cord out of the computer while walking passed.
Sony says I need a new battery, but I don't really believe them.
Anyone have any ideas?
    President:
  • 1,623 Answers
Sounds more likely you have blown part of the charging circuit when you have pulled the ac cord from the laptop
Posted on Jan 02, 2010
No sound icon on vaio with xp
That is a sign of a missing device driver for your audio. Download the driver on the manufacturer's support website.
Aug 07, 2014 | Sony VGN-FE550G: VGN-FE550G Core Duo T2300...
Won't boot up and fan not running
Sounds like a dead battery or power supply or both...check for a light on the power supply to prove it's connected.
Jan 09, 2013 | Sony VAIO VGN-NR285E/T Laptop
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
Hi, i'm having sony vaio (VGN NW380F) laptop. I bought this laptop just 1 year back. I'm having problem since last week, the laptop gets power off automatically. Its not specific to Operating system or any...
It could be a problem with the motherboard, basically because the power supply to the laptop is built in to the motherboard. I would first check the battery though. Sometimes this can happen with a bad battery, even if the laptop is plugged in. Try removing the battery and using the laptop while it's plugged in with no battery.
If it works fine with no battery and power cord connected, I would get a new battery.
If it is still a problem with the battery out, it's likely it could be a problem with the power supply that's part of the motherboard. If that's the case, I would try to call Sony and see if it is covered under warranty....or if they have had problems with this. With a year old laptop, this should not be failing like this.
Mar 30, 2011 | Sony VAIO VGN-NW380F/B PC Notebook
Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Mar 14, 2010 | Sony VAIO VGN-FE770G Notebook
My Vaio will not come out of standby mode without having to be shut all the way down and rebooted, I have adjusted the power setings to ensure that nothing is preventing it from going into standby mode....
If the 10-sec thing doesn't work, then try this:
- unplug the mains power.
- remove the battery.
- leave for a minute.
- fit the battery back.
- plug in the mains lead.
- try switching the laptop on.
If it works, then run Windows Update to download the latest fixes to try & stop this happening again.
If it does happen again, try going to the website of the laptop's manufacturer & check on their Support pages to see if they have a fix for your problem.
Jan 16, 2010 | Sony VAIO VGN-FE550G Notebook
Turn on my notebook and it goes into hibernating mode. Won't do anything and can't get it out of that mode. What can I do? Is it a virus?
If you are not plugged into the wall I would first say your battery is not charged. If it is plugged into the wall then you may have a bad power supply / cord, or try a different wall socket.
Dec 28, 2009 | Sony VAIO VGN-FE550G Notebook
Sony vaio vgn-a-150, doenst show screen, and i hear i clap clap, when the pc try to run but no.... just show 2 light in the front flashing
Remove battery, Power, memory, HDD and let the laptop for 6 hours.
Then connected the HDD>memory>Battery>power and try again,
JMC
Aug 14, 2009 | Sony VAIO VGN-A150 Notebook
Open Questions:
The Best Cheep Cloud Storage and Backup Services ' DataAlign You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Cloud Backup For Small Business services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Server Cloud Backup Solution Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Backup Pricing Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Aug 21, 2018 | Best Computers & Internet
Computers & Internet Logo
264 people viewed this question
Alun Cox
David Payne
David Payne
