Question about Propellerhead Reason 3.0 (991010004) for PC, Mac
Using the mic
How do I record using the mic
  • 175 Answers
I don’t think you can in REASON 3; it emulates a rack of hardware synthesizers, samplers, signal processors, sequencers and mixers.
Posted on Nov 10, 2007
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
I have a DELL Studio 1737 running Windows 7, with integrated web cam. i am trying to make videos with web cam and video is perfect but no sound on playback. Dell webcam central is what i am using to make...
Sounds like a software issue, possibly with webam central. There's a free player that has good codecs, and it may help you. Here it is:
This will be an easy fix if it works.
Jul 31, 2010 | Computers & Internet
I can't record video with sounds using that A4tech
Make sure your mic is set as default - especially if you have a laptop that already has a built in mic
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Feb 12, 2010 | A4tech PK-635 Webcam
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
Recording conversations which mic to buy?
How many speakers?  In a room?  Outdoors?  What kind of recorder do you use?  What is your budget?  Hi Fi or just need to be able to recognize what is being said?
Depending on your setup you might try:
Solution one: lavalier mics like an Audiotechnica ATR35 on each speaker's lapel.
Solution two: a boundary microphone on the table, like Shure mx395.
Solution three: cardioid pattern mics pointed at each speaker (could also use a shotgun).
Solution four: one figure eight pattern mic put between two speakers facing each other (make sure the axis of the mic points at the two speakers).
Solution five: you could scrap your recorder altogether and get a Zoom H2, put all four channels on and don't thump the table.
May 16, 2009 | Sony Audio Players & Recorders
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Propellerhead Reason 3.0 (991010004) for PC, Mac Logo
69 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
