Question about Dell Inspiron 640m Notebook
Inspiron 640m If I keep the computer on withtout using it (AC cord pluged) it turn off after 15 or 20 minutes. I tried other cords with the same results and without the battery. I'm not sure if the battery it's getting charged. Thanks for your help Ismael
  • 3,940 Answers
Portable batteries are considered a consumable item because as they are used, there is some degradation to the battery. The average life of a portable battery is 300 to 500 discharge/recharge cycles. After that point, the battery's ability to hold a charge slowly decreases, to where it will only power the system for 10 to 15 minutes even when indicating a full charge.
If this is the Original System Battery, then you will need to get a replacement battery to have the system run for a longer period on battery only.
Posted on Jul 03, 2009
My dell inspiron mini notebook wont turn on
Is it getting power? Check the plug at the computer for DC volts? Has the AC/DC jack in the laptop been damaged due to pulling on the cord? Try another cord/charger with the EXACT same power specs.
Mar 08, 2013 | Dell Inspiron Mini 10 Notebook
Battery light blinking orange once, then green twice
LOL, It means whoever sold you that Power Cord probably sold you one with the interchangeable end that can plug into any laptop. If it's not the interchangeable end type, they sold you one that is not compatible with your laptop. Get rid of it in a hurry before it burn out your motherboard. You my friend need to get on ebay and purchase a power cord designed specifically just for an Dell Inspiron 1525. All you need to search for on ebay is Dell Inspiron 1525 AC Adapter. They probably cost less than $10
Mar 21, 2012 | Dell Inspiron 1525 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
My touchpad goes out of control when it is pluged (inspiron 640m)
remove the battery and connect direct ac to laptop
hope this helps you
Jul 30, 2009 | Dell F3534 Touchpad
Computer does not work anymore
You could have a faulty adapter. Get it checked out and or borrow one to test your laptop to determine whether the laptop or adapter is at fault.
Apr 16, 2009 | Dell Inspiron 640m Notebook
I Need to locate the laptop reset button on it
to reset most labtops all you have to do is hold down the power button for about 15 seconds and it should reset
Mar 25, 2009 | Dell Inspiron 1000 Notebook
Power cord for computer
Looks like you have some issues with the port on the motherboard where the AC adapter is plugged in. Try another AC Adapter cord in, if still the same, then call up Dell to have the motherboard replaced.
Sep 23, 2008 | Dell Inspiron 6000 Notebook
Battery will not charge
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 640m Notebook Logo
204 people viewed this question
Alun Cox
