Question about Dishwashers
I put liquid dish soap--by mistake--in the rinse agent compartment. What can I do?
    Brigadier General:
  • 3,917 Answers
This is easy to fix, if you know what to do; and we do. First scoop out as much water as you can and dump it in the sink. Next add a cup or two of white vinegar and run the dishwasher for a short time. Now scoop out more water.
The vinegar cuts the foaming action of the soap. You may have to repeat the process to eliminate the suds because some soapy water remains inside the pump and hoses.
Also, if you poured it into the soap dispenser, wash that out by hand to get all the dish soap out.
It has happened many times in the past, and will certainly happen many times in the future. Someone pours dish soap in the dishwasher and all hell breaks loose. I can imagine many parents have had their kids do this type of thing and had to battle the outcome. I wish I could blame it on my unborn child but unfortunately, it was I, that poured dish soap into the dishwasher. Before moving on, look below at the images and get a good laugh. Alright, now that you have gotten that out of your system. Here are some ways to help get the suds to go away.
  • Sprinkle table salt onto suds.
  • Drop ice cubes into bottom to cool the water.
  • Scoop out as much water/suds that you can.
  • Try a cup or two of white vinegar.
    You may need to run it through the cycle 3 or 4 times to get the suds out completely. After the second cycle, my suds decreased pretty significantly. The second picture below is my wife's idea of a funny picture. Who ever said getting to the back of the dishwasher was easy?
    Thanks for contacting Fixya.
  • Posted on Jul 03, 2009
    How much salt goes in dish washer
    You don't put salt in a dishwasher unless you want to ruin it.
    2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
    3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
    4. Don't use any other product in the dish washer.
    Jan 30, 2016 | Dishwashers
    I put liquid dish soap (not even dishwasher soap) in my rinse aid compartment of my dishwaser...will this hurt the washer? Do I need to get soap out and how?
    yes it will foam up unlike you have never seen before
    by disassambling the door and removing the risne agent dispenser and very throughly draining the soap it may get all of it out(rinse it with only cold water since hot water promotes sudsing while cold water kills sudsing) if even a few drops remain it will suds like crazy during the rinse cycle (when the agent is dispensed) to remove all suds from the machine fill a cup of white vinegar placed in the upper rack such as if you would drink from it (not upside down) and run the d/w of a normal cycle
    a better but unfortunitly more costly solution would be to replace the rinse agent dispenser
    Jul 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
    The dishes do not rinse properly--despite rinse
    run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
    turn the rinse aid down to about half way.
    also check the phosphours content of you washing agent.
    there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
    reduce the amount of soap a little.does not matter if it is liquid or powder.
    once every three months you need to run cleaner through the machine.
    last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
    Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
    Accidentally put normal dishwashing liquid in the rinse aid space
    The amount you have put in although not good is not too serious.You can try putting nothing in dispenser for a few washes and see how that goes.If you are using the 3 or 4 in one tablets you should not need to dose with rinse aid or salt as it is in the tablets.
    Hope that helps.
    May 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
    Extra suds due to liquid soap in the machine overflowing. How do I drain it?
    This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
    REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
    Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
    Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
    I recently bought a different type of dishwashing detergent for my Frigidare dishwasher and my dishes look as if they have not been rinsed. They cycled all the way through the drying cycle so the detergent...
    the best way to use your dishwasher is the way it was designed.
    if your unit has a compartment for jet dry or rinse agent then you should add and fill that compartment with rinse aid. try not to buy soap with any extra like soap with jet dry or shine plus . because when you fdo that sometimes customer think that they dont need rinse agent . big mistake. rinse agent is deposited at a certain time in the cycle. diod you know that is you use lets say jet dry and a soap with shine plus or rinse aid in soap the machine can over suds? as a tech trust me i have seen it.let me know if i was helpful. drop a 4thumbs up post
    Feb 28, 2010 | Dishwashers
    Put rinse liquid detergent in dishwasher rinse aid compartment.
    I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
    Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
    1. Get some white vinegar--I used nearly a quart.
    2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
    3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
    4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
    5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
    6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
    7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
    8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
    9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
    10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
    11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
    I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
    Takes some patience but hey, beats a big repair bill!!
    Apr 04, 2009 | Kenmore Dishwashers
    Dishwashers Logo
    111 people viewed this question
    Top Dishwashers Experts
