Question about Xerox Office Equipment & Supplies
Need repair manual for Xerox XC1044 copier
I would like to repair my Xerox XC1044 copier myself. Is there a repair manual available? Thanks for any info you can give me.
Jennifer
norcalwell@sbcglobal.net
    Scholar:
  • 175 Answers
These manuals are usually only available to technicians in authorized dealerships. You might try ebay.
Posted on Jul 03, 2009
XEROX 8500 PRINTER FAULT 37,002.47:29330
From the service manual:
37,002.4x - PEST_FAULT_JSL_HEATER_DISCONNECT
PEST - Left jetstack disconnect.The left jetstack is not drawing the expected power from
the supply.
1. Run the printhead Left Jetstack Heater test.
2. Verify printhead wiring.
Yes, could be faulty printhead, but could be faulty power supply as well.
I have the full service manual available if you need it. Please take a moment to give this solution a rating of fixya. Thanks!
May 16, 2012 | Xerox Phaser 8500N Printer
Toner NOT sticking to paper
"Cars & Trucks" is not the correct place to post your question for your Xerox XC1044 Copier. However, I can tell you that the heating element in your drum assembly is most likely defective. That is why the toner is not sticking...it is not getting hot. You will have to replace your drum assembly to fix it.
HINT: on an older copier/printer like the XC1044, it is usually just as expensive to replace the drum assembly as it is to buy a new copier/printer. You should probably shop around before putting any money into it.
May 02, 2012 | Cars & Trucks
XEROX Phaser 6100 service manual
We have the Phaser 6100 Service manual available at:
http://www.ccl-la.com/catalog/
Jul 20, 2010 | Xerox Office Equipment & Supplies
Xerox copier model #XC1044 paper will not come out of the pathway, will only copy the first half of the sheet. Is this worth fixing, copier has never been serviced in 11 years! Do I need a new copier?...
Most likely the gear that drives the fuser heat roll broke.
It would be laying in the back of the machine about 2/3 of the way through.
Its not an expensive part nor hard to change. Just open the machine, look toward the back behind the hot area of the machine, I am guessing you will find broken pieces of gear. If so let me know and I will tell you where and how to replace it.
Jan 29, 2010 | Xerox Office Equipment & Supplies
How do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
322 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
