Question about Locks & Locksmithing
My front door has a Roto R627 lock. I can't get
My front door has a Roto R627 lock. I can't get the dead lock to lock. I have tried turning the handle upwards to open out the other deadlocks and slide locks, they work okay, but when I turn the key to engage the central deadlock, it wont budge. It means I can't use any of the deadlock features on my door and just using the single barrel lock. Can I fix this? I dont want to buy a new lock if I can avoid it.
    New Friend:
  • 93 Answers
If the deadlock moves a little bit, The deadbolt may not be lining up with the hole. Put some lipstick on the deadbolt tongue and try to turn it. Then check where it is hitting the frame. You might have to just tighten up the hinges to shift the door position.
Posted on Mar 22, 2015
4 Suggested Answers
karmacanic
  • 16 Answers
SOURCE: Door deadlocks
take the lock apart & rotate the flat metal actuating rod 180 degrees & re-assemble the lock.
Posted on Oct 27, 2008
  • 6 Answers
SOURCE: MY FRONT DOOR KEY WON'T OPEN THE DEADLOCK - MUST
take the lock apart, the tailpiece that connects to the keyed cylinder probably fell off
Posted on Oct 03, 2009
tbirdfan1
  • 3051 Answers
SOURCE: how to recode a keyless deadlock
Hello there:
these locks have a master card or code that will reset the programming mode and allow you to reset the code. i would suggest contacting the manufacture of the lock and request the code or the card ok?
best regards michael
Posted on Oct 06, 2009
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
How do I fix a lock that is jammed?
Contact the builder of the doors of the Summerhouse or go to the lock companies website. There may have been a faulty batch or known fault identified on these locks you have fitted.
Alternatively contact a local locksmith who could give tyou advice..
Mar 01, 2015 | Locks & Locksmithing
Hi I have an iseo lock on my reasonably new summerhouse and although i have the key and the key turns both ways in the lock, apparently engaging and disengaging the lock on a single turn each way, i cannot...
You should be able to feel the lock disengage. Also feel the latch moving. If you can feel this, then the door is jammed, not the lock or handle. They do swell. You'll just have to force it open. You might try spraying some lube at the top and bottom, where you suggested it feels stuck.
Mar 01, 2015 | Cars & Trucks
I have a mondeo 2.0l serve x the 2000 car I can open the front drivers door with the key or fob passenger door I have to use the key but both back doors wont open at all they are deadlocked it seems t
Are you saying they won't unlock with the power unlock or that they cannot be opened from the exterior and interior handles? If you can't open with either latch, then there is a mechanical problem with both doors. If you add info or clarify, please add to original question via comment.
Jan 06, 2015 | Cars & Trucks
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
Remove the seat and door pad. You can access the lock through a small hole. Break the top inner corner of the lock to release the dead lock and open the door.
Jan 24, 2014 | 2004 Volkswagen Golf
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
Honda civic stuck in deadlock can't open any doors as the key won't work in any of the door lock's or boot
Try having a new key cut using the key code, at a dealer, not tracing the old key.
Feb 25, 2013 | 2003 Honda Civic
Peugeot 406 HDI 2001. O/S rear door dead locked.
Deep joy. This can be a royal pain. The only way I have successfully done this is to put a battery charger on the car overnight, locked, and then when the battery is sitting at about 15v unlock it with the remote - when the lazy deadlock is stirred into action. It can take a couple of attempts. It really is incredibly difficult to get to. Otherwise, its most easily a case of breaking the unit...though you could try taking the leads off and applying 18v to the solonoid directly. That was my next move, but never needed to get there. You can however stop the deadlock from locking, by cutting one of the wires, test using a multimeter which one is live when you arm the alarm/deadlock the car. Thats also the one to apply 18v to if you want to.
Jul 05, 2009 | 2006 Peugeot 604
Locks & Locksmithing Logo
1,645 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
