Question about iRiver iFP-790 MP3 Player
Drivers and more memory installed
How do I achieve this.
  • 3 Answers
Go to the iRiver web, you can find the adrress on your Iriver manuals book.
in the website you can download everything such as firmware, aplication, and drivers of your iriver.
try it, good luck
Posted on Nov 10, 2007
My Gateway DX300X desktop is super slow and only has 0.99 GB of RAM. How do I install more?
According to specs, your computer can use up to 4Gb of memory. You will need to open the case and see what is currently installed. You should have 4 memory slots and probably it came configured with 2 512Mb memory sticks. You could add 2 more sticks of 1Gb each bringing your total up to 3Gb, but my suggestion would be to remove the existing memory modules and install 4 matching 1Gb modules. You must use DDR2 PC2-5300, DDR2 (non-ECC) type memory and the best results will be achieved by using all matching modules.
Oct 21, 2013 | Gateway DX300X PC Desktop
How to find and install ALL Windows XP Drivers easily
Finding and <a href="">installing drivers on a Windows XP</a> system can be tiring. Here is an easy way to achieve this: <a href=""></a>
on Jan 14, 2011 | Computers & Internet
Youcam driver
Just go to google and visit the ASUS official website and type on the search engine the model and type of your Laptop. Or while you are on the site, look for support, then look for the camera drivers that are compatible with your laptop. You can achieve this by selecting the notebook, then select the series and model of your pc. Then download the drivers that you need from the list and install them in your computer
Sep 16, 2013 | ASUS Laptop / AMD Turion II Processor /...
Vram is 256 mb but dedicated is 64 mb and shared is 192mb . how do i change it.. no option in bios also. Sony vgn n220e
You should not change this. Laptops have small video chips and often depend on "shared" memory to achieve good performance without overheating. Basically, the video processor borrows some of your installed RAM memory. Also, your laptop may have been supplied to you with less total RAM memory than the maximum and you can add more memory. In Windows, click on Start then right-click on Computer and select Properties. In the Properties window you can read how much total memory is installed. 2GB (2048MB) is a desrirable amount for Windows XP. Windows Vista and Windows 7 can benefit by having total 4GB of RAM memory. Check your Sony user manual for instructions on adding more memory. Basically, you turn off the laptop, remove the battery pack and unscrew a small cover on the bottom of the laptop to access the memory slots. Usually, there are 2 slots here. Ideally, you should install a matched pair of memory modules (a "kit") for peak performance. However, quantity of memory is more important than having matched modules, so if one slot is occupied and the other slot is empty you may simply buy one more module and install it in the empty slot.
Aug 13, 2013 | Sony VAIO VGN-N220E/W Notebook
When using some programs, the screen is too big for the monitor so that images and text disapear off the side. How do I fix this?
Looks like your monitor is rather too small for the application/programme or you do not have drivers installed for the vga (graphic card)
Most or almost all programmes use the default and common screen size of 1024 x 768. and this cannot be achieved on older monitors or even on some smaller modern monitors and also when you do not have drivers installed for the vga.
To achieve this follow the steps below
  1. Right click on the desktop
  2. choose properties
  3. click on the settings tab
  4. use the slider and set the screen resolution to 1024 x 768
  5. accept to use that new resolution
  6. click ok and you are done
NOTE: To know if drivers for the vga are installed and working properly, perform the following steps from 3 above
  • after clicking on the settings tab
  • click on advanced
  • from the new dialog box click on the "adapter" tab
  • make sure that the memory size and relevant information is not showing as -unavailable-
  • look at the picture below for example of a pc with drivers installed and the vga set to 1024 x 768.
NOTE: The screen size may sometimes go higher that what i have stated and that should also work well only if your monitor supports that size well enough.
Aug 04, 2011 | HP GX612AA Pavilion Media Center M8330F...
Using Windows XP with a terrible, terrible video card. Will not go above 640x480 resolution. Only has 8mb video ram and Windows won't let me raise past that. Was wondering if there was any way to force...
if windows does not have the correct driver for the graphics card the resolution may be stuck at a "safe" setting, try downloading and installing a graphics driver, if the graphics card is very old and its maximum resolution actually is 640x480 there is no way other than replacing the card to achieve a higher resolution
Jul 25, 2011 | Computers & Internet
Why Windows 7 dell laptop does not take TATA PHOTON driver even after installation of the tata photon software.
Hello Friend,
Uninstall the driver first. Now re install the driver with administrator rights. This can be achieved by right-clicking on setup file and select "Run as Administrator"
Good Luck!
Dec 21, 2010 | Computers & Internet
How do i install my camara without a cd?
you can only achieve this by downloading your webcam software from the internet and install it on your system.
The driver downloaded will serve as your Cd. Without the drivers, there is not way you can install your webcam. The driver is what you have on the Cd.
Good luck.
Good luck.
Apr 15, 2010 | GE MiniCam Pro HO98756 Webcam
Graphic Problem
This might be an issue with not having full rights within the BIOS, you could try to enter the BIOS and press F8 this sometimes reveals 'hidden' features.
Dec 20, 2008 | Intel Motherboard
USB 2.0 Drivers for Windows 98 needed
Dec 06, 2008 | Ricoh (1000014525) 25 Pack 8x DVD-R...
iRiver iFP-790 MP3 Player Logo
48 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
