1997 Saturn SL Logo
A
Anonymous Posted on Sep 19, 2014
1997 saturn stalls when starts rough idle will stay running if you give more gas
Rough idle when starting will stall if you don't give it the gas
jeff5may32
Level 3:
  • Saturn Master 1,258 Answers
  • Posted on Sep 20, 2014
jeff5may32
Saturn Master
Level 3:
Answers
1258
Questions
0
Helped
375107
Points
5289
Check your oil! then check for fuel pressure.I bet you're low or out of oil.
5 Related Answers
Anonymous
  • Posted on Jan 17, 2009
SOURCE: car hard to start after engine is warm
Sounds exactly like what I was dealing with a while ago. A nuisance (especially at fuel stations & such, where if you don't get it right away you end up looking like an idiot as it just turns over & over).
For me, it was my fuel filter. The previous owner had neglected the car so much & I had no idea how long it had been. $50 at an Oil Can Henrys & it was all back to normal. Great first step.
volvo2103
Gary Loney
  • 122 Answers
  • Posted on Jan 30, 2009
SOURCE: 04 Saturn stalling on take off and stops.
Pour the fuel injection cleaner to it....sounds like the injectors are dirty.....
Anonymous
  • 407 Answers
  • Posted on Apr 29, 2009
SOURCE: 91 saturn sl1 code 26 stalls at an idle when in d or r
its possiable the computer has a bad quad driver, before throwing parts at it, take it to a shop and have it verified
Anonymous
  • 1244 Answers
  • Posted on Jan 19, 2010
SOURCE: 2002 SATURN SC1 IDLE JUST STARTED BEING TOO LOW
change the TPS also check the air idle control valve
Anonymous
  • Posted on Mar 13, 2010
SOURCE: 98 Saturn SL2 - Stalling issues
I had a problem with starts on my 98 sc2, did it twice only, but it would start up, shake a bit then shut down like it wasn't getting fuel, or a wrong mixture. Replaced the coolant temperature sensor and starts / idles like new now... goodluck
2001 dodge dakoto ran stopped at store turned engine off, back to start engine started but run rough an stalls . wont stay running without foot on gas but runs rough and stalls when take foot off gas
This could be he Idle Control Valve and is around 50 dollars and a easy fix. Also try STP 5 in 1 fuel cleaner for a couple of tanks if you are using the cheap gas
2answers
89 ford probe hesitates when leaving a red light, then runs fine otherwise, fuel filter?
Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard ...
repairpal.com > Problems > Ford > Probe
Ford Probe Engine Runs Rough, Stalls, Hesitates on Acceleration, Hard Starting, Poor Performance. This is a verified problem based on 9 reports. Learn more ...
Starting Problems - 1997 Ford Probe - RepairPal
repairpal.com > Questions > Ford > Probe > 1997 Ford Probe
Dec 5, 2010 - Starting Problems on 1997 Ford Probe ... If the engine runs rough,stalls, hesitates on acceleration, is hard to start, or has generally poor ...
A new misfire/hesitation on accel. Problem.. - ProbeTalk.com Forums
forums.probetalk.com > Tech Section > 2nd Gen (93-97) V6 2.5L
Stalls after start up, Stalls when braking, then runs fine after a few minutes
If it stalls when the brake lights come on then the idle is too slow. The high amps of the lights will load down the engine and lowers the idle.
Sometimes that's caused by a vacuum leak near the manifold area.
Sometimes air in the coolant will cause an idle problem. Air will keep the air temp sensor from sending proper info.
Hope this helps.
Hope this helps.
1helpful
I have to give gas to start if not the car stalls
need to have a fuel pressure test also make sure egr is not open at idle car wont run with egr open at idle
2answers
1995 safari van w stalls when giving it gas. changed fuel pump and filter. replaced egr valve. sometimes rough idle. when it stalls just like you turned off key. then when you try to start it acts like it...
maybe your iac valve is not working? it takes place of a choke or temp sender to computer could be bad which controls t I.A.C. known as the idle control valve,do you have any codes?
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
