Question about Grilling
Perfect flame model SLG2007D when 1 of 5 is lit no problem, when a second burner is lit flame goes out? is there a manufactoring website, i cannot locate my owners manual?
    Scholar:
  • 127 Answers
Probably a defective regulator or a leak. Regulators have a safety feature that shuts them off if there is insufficient back pressure, such as can be caused by a leak. If the leak is of the right size, then the regulator may be happy with one burner and the leak, but any more and it shuts down. Carefully inspect all hoses and fittings. A soap and water solution may help. Be aware that varmints like to chew on the rubber hoes, especially if they get grease on them. These can be hard to spot. If no leaks, then the regulator may be defective.
Posted on Jul 07, 2009
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Water heater goes out
The burner needs to be adjusted
Mar 13, 2017 | Water Heaters
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilot will stay lit but burner goes out about 1 minute after it lights
Sound like the flame sensor you could scratch around on it and try again.Possibe venting issue
May 14, 2010 | Water Heaters
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Empire BF-30-1 Main Burner problem
flame sensor,just take some fine sand and lightly sand,it will be where the flame hits one of the burners,should look like a probe,if this helps please give me a fix ya
Jul 11, 2008 | Empire Heating & Cooling
Grilling Logo
329 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
