Question about Toshiba Satellite A60 Notebook
DVD LED LIGHT CONSTANT ON AND COMPUTER DONT TURN ON
THE COMPUTER TRYS TO START BUT THE FAN STOPS IN AFTER 10 SEC THE LED LIGHT OF THE DVD BURNER STAYS ON , THE SCREEN IS BLACK AND I HEAR NO SOUND OF THE HDD WORKING NO BEEPS OR ANYTHING AT ALL. I NEED HELP WITH IT B/C IT STARTED AFTER AN UPDATE OF WINDOWS AND THEN IT RESTARTED BUT IT HAD TO MUCH LAG AFTER AND I HAD TO TURN OFF BY PRESSING AND HOLDING THE POWER BUTTON AFTER THAT I TRIED TO TURN ON AND IT DIDNT WORK.
Acer Aspire fan stops after starting led light stays on
Same thing happened to mine. My fan just needed replaced.
Dec 21, 2013 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 wont start
Trying doing a Hardreset
Remove the adaptor and Battery and press the Power for about 30 secs
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
When i turn the computer on it starts then
SOS beeps are post codes the computer sends to alert you of problems detected during start up.
The beeps can mean anything from over heating to bad memory detected. Find out what your Motherboard bio is and check Here. This has a handy beep code listing for many of the common mother boards.
Hope this helps!
Nov 17, 2009 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
The drive doesn't read cds but can read dvds!!
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and then DVD , it's normal. Pls rate my solution if I helped.
Jul 28, 2009 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
Computer will not turn on. power supply is ok. when on botton is pushed for the first time battery led flashes 10 times and stops. fan does not go on. 2nd time the power button is pressed, the battery led...
Hmmmm, I'm thinking DUST has clogged your fan and the CPU is overheating and shutting down your computer. Find a way to blow some air through the vents in the case. This may loosen up any dust and if your lucky it'll blow out. Only other thing I can think of is to open the case and take a look.... if you are confident enough. If not don't.
Jul 24, 2009 | Dell Inspiron 5100 Notebook
Toshiba Satellite A60 Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
