Question about Sony SA-WM500 Subwoofer
Subwoofer Line In/Out Mix-up
I recently moved, so I had to re-connect all of the wires and speakers to my stereo.
I have a Sony SA-WM500 subwoofer and a Harman-Kardon AVR 635 amplifier/receiver. I accidently plugged the line out from the amplifier to the line out in the subwoofer and left it like that for about a week. When I realized my mistake, I switched it to the line in on the subwoofer. However, now I am not getting any sound at all.
I have an energy saver feature on the subwoofer, and I noticed that when I do test the subwoofer from the amplifier, the energy saver causes the subwoofer to turn on. Thus, it does seem to be receiving a signal.
Does anyone know what has happened? Have I damaged my receiver/amplifier or speaker, or both by making this mistake?
    Problem Solver:
  • 7 Answers
Re: Subwoofer Line In/Out Mix-up
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
Posted on Jul 13, 2008
0 characters
3 Points
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
Sony discontinued parts, how can I get complete working fully functional ICB's for the Sony Powered SA-WM500 Sub Woofers? Got 6 and butchering 1 too fix another is totally out of the question.
Sep 08, 2013 | Sony SA-WM500 Subwoofer
Get manualget manual
May 19, 2012 | Sony SA-WM500 Subwoofer
The fuse blows in the SA-WM500 whenever there is an input from the amplifier.
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Jan 17, 2011 | Sony SA-WM500 Subwoofer
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
Jan 11, 2011 | Sony SA-WM500 Subwoofer
Have a 8 ohm receiver and the sa wm500 which is 6 ohms. how do I match the ohms?
In your case a 2 ohm difference would not affect or hurt anything.
Jan 21, 2010 | Sony SA-WM500 Subwoofer
Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms will put a lead on each of the terminals of the should have a reading of 2, 4, 8 may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Aug 09, 2009 | Sony SA-WM500 Subwoofer
Replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
May 18, 2009 | Sony SA-WM500 Subwoofer
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Sep 25, 2008 | Sony SA-WM500 Subwoofer
Sony SA-WM500 Subwoofer Logo
797 people viewed this question
Top Sony Speakers & Subwoofers Experts
Sanath Kumar V
Are you a Sony Speaker and Subwoofer Expert? Answer questions, earn points and help others
