Question about Gateway (4000274) Motherboard
Turn the comp. on only thefans come on.
Turn the comp. on only the fans come on. Already replaced the power supply samething.
  • 95 Answers
It could be a bad RAM stick or a bad CPU, or if you know the insides of a computer good then unplug your CDROM, & hard drive (both cable to each drive), and if you have any cards on your PCI slots remove any of them but the video card. Also, keep your mouse and keyboard plugged in. Then try it.
Posted on Jul 23, 2009
Fan wont turn when oven is on
then one might think the fan needs replaced .nothing lasts forever
Jun 29, 2015 | Ovens
Computer won't turn on.
There must be a problem with your power switch on your computer casing, or motherboard or power supply.
Detach your power supply and try this, to check if your power supply really works. If the auxiliary fan will turn, your power supply is good
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-0.jpg Testing your power supply and motherboard as seen on photo
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-2.jpg If the cpu cooling fan and power supply did not turn the fan, but you have checked already the power supply that is working then you can conclude that your motherboard is need to be replace. But the power supply and motherboard and working, meaning to say your computer casing need to be replace or try fixing the contact of the switches attach to your casing.
Have a good day.
Apr 04, 2015 | Dell Studio Xps 9100 Desktop Computer
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
Hello, I'm replacing my dell 530s power supply with a 350w. Porblem is, the fan will run with the 4-pin disconnected, but nothing when connected.
as you said when the 4 pin conector is connected thefan just spin one time and stop theat means the power supply section in the motherboard is not working you will have to take the motherboard to a chiplevel service engineer the FET in your motherboard has been fried you need to change them
Jul 02, 2011 | Dell Inspiron 530s Desktop Computer
Not sure if it is MB or CPU when i try to turn on computer the only thing that happens is i hear a beeping sound. beep...beep...beep... continually. it wont go to the post, nada. the fans run and i have...
Continous beeps usually mean the motherboard or the power supply, Try another power supply first and see if it will boot, if not the motherboard is faulty, if the prossesor was faulty you would no beeps the fans would run but nothing on the screen. hope this helps.
Aug 24, 2010 | Computers & Internet
What happens if one powers on a laptop compaq evo n110 series
it's likely the fan has failed. it should immediately shut down and even if it doesn't... if the fan is not spinning you need to put a new fan in first. it is easier to replace a fan then a cpu and heat will basically kill it.
Dec 03, 2009 | Compaq Evo N110 Notebook
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
Playstation 3 60GB
I suggest a new cooling fan in the unit..
Its easy to replace and costs 15$...
I suggest also getting an intercooler deal from walmart before your power supply goes or the mother board blows..
Hope this helps!
Jun 27, 2008 | Sony PlayStation® 3 (60 GB) Console
Cpu fan wont come on after new power supply put in
what made you change the power supply to begin with? Most cpu fans run off the motherboard, but the motherboard initially gets all voltages from the Power supply to begin wth. Did you assume that because cpu fan wasn't running to begin with, that the original power supply was bad. Not a bad assumption but one that needed verification before changing out a power supply. So it seems at this point that you have an unverified bad power supply, a possible bad motherboard, and a known good cpu fan. Plus at ths point you really don't know of the new power supply is good yet until you see something electrical run with it.
Feb 27, 2008 | Intel Motherboard
Gateway (4000274) Motherboard Logo
184 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
