Question about Garden
Briggs & Stratton 7 hp mower starts then stalls. Plug is not fouled. It seems to be a fuel problem. The primer works but once it starts it doesnt get fuel
  • 68 Answers
Usually means the main gas jet is plugged with dirt or sludge, the carburator will have to be taken off and cleaned, and use compressed air or a small wire to clean out the little orifices.
You might have to clean the fuel tank also.
Posted on Jul 04, 2009
Riding mower wont start
if the carburettor is fine and the choke is working, check the ignition timing.
May 19, 2016 | Briggs & Stratton Briggs Stratton Intek V...
Engine seems to run fine as long as the plug is not fouled however it smokes and leaks oil from the fuel pump. It seems as though there is too much crank case pressure
oil from the fuel pump may indicate a failure of the diaphragm of the fuel pump and petrol is getting into the sump
that will raise the oil level to a point where the oil ring can longer control the oil getting to the top of the piston
it is possible that the sump breather hose is blocked or if it has a small pvc valve that that is blocked
May 06, 2016 | Briggs AND Stratton Intek Briggs &...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
My craftsman 917.370722 lawn mower (6.5 hp Briggs and Stratton motor) won't start. I replaced the dirty air filter and spark plug, which was fouled. Then it blew puffs of smoke out the exhaust but still...
thake out the plug and pull the cord a few times that should clear any oil on the head clean plug and try again if the mower is old the piston rings are either worn or broken allowing oil to get into the fuel .
Oct 22, 2013 | Mtd 22" Yard Machine Push Mower
The 'primer' doesn't work on my mower's Briggs & Stratton engine. Is there an easy fix?
You can try pumping primer bulb 10-15 times instead of 3 or 4 that manual probably suggests. We have a craftsman 22 inch cut push mower with a 3.5 H.P. BRIGGS &STRATTON engine and if you don't prime it at least a dozen times it will not start. It is possible that you have a small hole in your primer bulb in which case it can't create suction to bring gas to carburator. If this is the problem you can purchase a new bulb and seal at most larger SEARS stores or service centers.I would guess that if you have manual for mower you can get part number and phone number to get new parts .Hope this helps. Thanks
Nov 08, 2010 | Garden
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
Engine starving for fuel, fuel filter very low, almost empty
your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
May 30, 2009 | Craftsman Garden
Stalling Briggs & Stratton engine
carbeurator needs torn apart..cleaned and reset.
Sep 01, 2008 | Garden
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
