you need to call the gm part department and ask for a fuse diagram they can print you out one so you can keep it wwith your vehicle. Please rate my response thak you very much
Do you know what a wiring diagram is ? A wiring diagram for your vehicles windshield wipers electrical circuit would show all components involved . You would need a wiring diagram for testing ,so you know which wires too test . It would show the fuse location - amperage etc.... Which of these is your vehicle - Notchback or hatchback or station wagon .
The fuse would be marked WPR fuse # 9 25 amp. located in the IP fuse panel . IP - instrument panel fuse box . It's location is
Fuse Block - I/P
Behind the left side of the I/P access panel
Windshield Wiper System
The windshield wiper system consists of a wiper motor, a linkage, a wiper arm and a blade, and a wiper/washer switch. The windshield wiper circuit incorporates a self parking device which consists of a worm gear and a cam plate in order to keep the circuit engaged temporarily when the switch is turned off. The wiper system is driven by a permanent magnet-type motor. The windshield wiper motor is mounted on the dash panel and is directly connected to the windshield wiper linkage.
The windshield wiper motor has 2 speeds, LO and HI, and also has intermittent wiper capability. The wiper switch is an integral part of the wiper/washer switch. Windshield wiper operation is actuated through the lever on the right side of the steering column.
If you still have the owners manual the fuse identification and location is in that book, Otherwise, you can get a manual for your vehicle at an auto parts store.
Go here http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter your vehicle info. year make model engine size . Under system click on Electrical distribution . Then under subsystem click fuse panel . Then hit search an two blue links will pop up . Click on them one at a time . The first link will show at the lower right side of fuse box the Wiper/ washer relay ! The second link shows the 1 touch down relay . When you check those out go back to system an click on body an Accessories ,then subsystem click on power windows . Look at the wiring diagram an do the same for the wipers / washers . Good luck !
Below dash instrument panel, R16 ignition relay 98 Ford Contour SE Fuse Box Map Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
This question has been asked here before, except for a 95 model. The advice given is still sound. http://www.fixya.com/cars/t17448724-fuse_diagram_1995_mack_dump_truck
AutoZone.com has a free manual database you can access by creating a free account and adding your car to your online garage. The manual has fuse diagrams.
