Question about GPS
Have a tomtom 910go gps will not recognize usb and it shows a big red X. treid to reboot it and I left it on pc to try to reboot it and the only thing it did was nothing
  • Tony Benson
    Tony Benson Jul 03, 2009
    TRIED THAT IT DID NOT WORK
  • 3,230 Answers
Follow the link below -
http://uk.support.tomtom.com/cgi-bin/tomtom_uk.cfg/php/enduser/std_adp.php?p_faqid=1898&Lid=1
Good Luck!!
Thanks
Posted on Jul 03, 2009
  • Mukesh Kumar Jul 03, 2009
    that means there is some hardware problem in your GPS system.
My pc does not find my tom tom
1. Try rebooting.
2. Only plug in USB link when Windows is up and turn on the tomtom first.
3. Install Tomtom home from their site.
4. Try another USB lead, not the tomtom one (just in case that one is the fault.)
Mar 05, 2010 | Tomtom ONE GPS Receiver
TOMTOM Home does not recognize my device
reinstall tomtom home from tomtomsite. smetimes it also helps to use another usb port. good luck
Feb 12, 2010 | Tomtom ONE GPS Receiver
My TomTom one xl is showing a big red X on the opening screen . and cant do and thing else.
If you have a big red circle with a white X in it, indicates that you have a serious problem with your unit:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) If above does not work, connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
3) If above does not work, and this is usually the solution for 'big X error', use TomTom Home to restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom GPS
My tomtom is connecting fine to the computer, but once I get the pop up window saying my device is safe to properly disconnect and I disconnect it and try to turn it on without it being hooked up to the...
If you have a big red circle with a white X in it, it usually means that your TomTom One 'disk' is corrupted: first try a 'hard reset' , while the power is on, stick a small (tooth) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressur on the stick will cause a complete system reboot if possible.
Next, since you can connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
If there is an error or you cannot reboot, hopefully you have a backup made either by copying the whole unit disk content or more traditionally via TomTom Home, I would suggest a complete restore your device content follow by a TomTom Home device update.
Hope it helps: let me know how you go.
Jan 05, 2010 | Tomtom ONE XL GPS
TOMTOM GO930 not booting up! BIG RED CROSS!!!
I just coped back the file 'system' from an older backup and The GO930 booted again. So, if you have a Backup, you mi9ght try that.
May 02, 2009 | Tomtom GO 930 GPS Receiver
Replace the battery for tomtom 910go
hi take out the screws from the back x4 to get to them lift the ends of the rubbers ,once you've done that lay it flat on its face and lift the back it should slide out .now you have to unscrew a couple of pcb(printed circuit board),remove them and voila your battery you can buy it on ebay and matter of plug in plug out . hassan
Jan 22, 2009 | Tomtom GO 910 GPS Receiver
Not recognizing memory card!
I had the same issue after installing updates, I contacted tomtom & they talked me through it.
I think i had to wipe the card & through my tomtom home software they reformated the card & go it sorted.
http://www.tomtom.com/support/index.php?Lid=1
Nov 25, 2007 | Tomtom GO 300 GPS Receiver
PC not recognizing Tomtom
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
Nov 12, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
