Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
TV suddenly stopped working - won't switch on from top - won't respond to remote - no standby light - fuse is fine - set is 3 yrs old
  • 668 Answers
The Power Supply is probably causing the problem if you are not getting any response or LED flash or Stand by
Posted on Jul 04, 2009
Tv will not come on with swith on tv, don't have remote
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 10_30_2012_4_55_47_pm.jpg
Oct 29, 2012 | Emerson LC320EMXF 32 in. LCD TV
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
My panasonic Quintrix tx28pl1was working fine then just stopped working when I walked away, it now only has the red standby light on and won't go any further despite pressing buttons etc. I've left...
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_30_2012_12_36_36_am.jpg
Mar 29, 2012 | Panasonic Televison & Video
No standby light
Depending on the brand and MODEL number here is what I think happened.
All TV sets have a Standby power supply. It runs all the time even if set is off but plugged in.
It supplies among other things the power (usually less then 12 volts DC to run the remote circuitry---It usually is not fuse protected so if a strike hit nearby it may have come in via the power cord.
Trouble is almost certain to be in the standby supply.
Mar 17, 2012 | Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
It suddenly stopped working. It is 3 yrs old.
i restore my opperatting sistem and cant access my drivers again
Aug 31, 2009 | Dolphin Maytronics Diagnostic Robot...
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
Phillips 32" tv stuck in standby mode
thesupply is not responding
take your tv for repair
let them check power supply
semi conductors, transistors, zener diodes, an dfuse resistors, also check the switch contact,
and fuse,
Dec 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Won't turn on. Plug is fine. Remote is fine. No standby light. No click when remote ON is pressed. Set is 7 yrs old, never been moved, no other problems ever.
If you are sure that the a/c outlet is good, try another. No lights, no clicks your main fuse in your unit may be open. CAUTION: if you replace main fuse with same value & it opens again. STOP and call a servicer. You might have shorted electronic devises in the main a/c circuits. Always call a service company that is factory authorised to service your product. Good luck.
Apr 02, 2008 | Televison & Video
Sharp 34" TV
Why shouldn't it be worth fixing? It's only 4 years old, my own TV is 15yo, I fixed it twice but it's still kick'n! You have a problem in the power supply, do you have electronic's know how? And test equipment? Soldering equipment? If so we could walk you through it, If not A repair man should only cost 80 to 100 to fix it.
Aug 13, 2007 | Sharp 32C-240 32" TV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
477 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
