Question about Plumbing
Grohe shower head is leaking. it is a glidebar system. how do you get access to the valve? don't see a allen screw to remove handle. ??
  • 297 Answers
Most likely ther is a cover on the handle.if the line is attached to the wall, the cover plate on the shower wall just unscrews. there is no allen key.
Posted on Jul 15, 2009
How to remove handle on single handle grohe shower valve. no screws on handle
There should be set screw on bottom of handle it very small it's a Allen wrench set screw
Jun 12, 2016 | Grohe Home
The handle to switch between the overhead showerhead and the handheld wand won't turn.
Look to a small hole on the adjustment handle there should be a small Allen screw. Loosen the Allen screw set the handle to the desired position then tighten the Allen screw.
Jan 29, 2016 | Grohe Aquatower 3000 Shower Tower...
There are two shower handles, one to divert to the shower head and another to divert to the rain head. one of these handles has loosened and falls away from the neck.
Look for an Allen screw hole the Allen is loose or has stripped and needs to be changed out. Sometimes if they are over righted they strip on bottom, also make sure it hasn't backed out completely. Some older handled have a square piece that the handle goes over then the screw is tightened under a plastic cap tha has hot H or cold C on cover.
Aug 29, 2015 | Grohe Home
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
The black coating on the handle of our grohe kitchen faucet was chipping so Grohe sent us a new handle. We have tried all sorts of muscle power and tools and simply cannot get the old one to come off. Is...
Is there a little emblem or similar in center of handle that pops out to expose a screw or allen key style screw? Also check around base of handle,(almost standing on your head) for a n allen screw head as well, or any area that looks like it might pop out .
Dec 31, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Jan 19, 2009 | Plumbing
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Plumbing Logo
352 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
